Question about Car Audio & Video
My car is shutting the power off completely while driving i have a new battery too..
Just opening the hood and see whats up and the power is back on as nothing ever happened
    Problem Solver:
  • 7 Answers
More than likely it's the alternator. Have it checked at a local parts store usually they will test for free
Posted on Apr 29, 2014
I have a 2006 Hyundai Sonata, I had it for 3 months now and it will not start, the car shut off on me while I was driving it in my neighborhood, I can't even open my hood to check under it, what shoul
You know the instruction how to open the hood is under the hood :)
Grab a pliers and pull on the cable to open the hood
inspect the battery terminals for good connections and make sure the battery is fully charge. jump start and using a volt meter check for good charge from alternator 13.5V-14.2V
post more information to get more help
Good luck
Apr 20, 2014 | 2000 Hyundai Accent
What is wrong with my 2003 BMW 525i?Battery Drain
excessive power loss due to alternator bad..take to parts store so they can check it..diode trio is bad letting power back thru the alternator..basically it wont shut off now and will kill the battery after several hours..
Dec 26, 2013 | BMW X5 Series Cars & Trucks
I replaced the battery (brand new) in my 1990 Ford Taurus. The car started instantly and a few hours later I had to move it and it started perfectly again. When I went to drive it a few days later it was...
Fusable Links corroded,leaving at least
one circuit open
Start at the battery on the wired side, and work
your way along until you find the links,if have
no diagrams to use
Check,remove and clean all ground wires under hood
Apr 22, 2011 | Ford Taurus Cars & Trucks
2006 Hyundai Tucson Car - the battery is totally drained & dead so it wouldn't open with the remote opener. Now that we used the key when the car starts to get battery power back the alarm sounds...
this is for honda acura but it also might work for you too.
Open hood ensure new battery is disconnected.
Open main fuse panel cover under hood and remove horn relay (so you don't have to listen to the horn).
Use the key to lock the drivers door.
Connect the positive battery terminal.
Connect the negative battery terminal (security system will now activate, hazards lights will flash and horn would be going off if the relay was not removed).
Use the key to unlock the drivers door.
Get in, close drivers door.
Use the key to start the engine.
Security system will deactivate.
Get out of vehicle, reinstall horn relay, replace fuse panel cover, close hood.
Oct 15, 2017 | 2005 Hyundai Tucson
Car's power completely shut off when driving. 1998 Malibu
Problem is either the battery or the terminals that go on the battery. Remove and clean both terminals and if the problem persists replace the battery.
Sep 09, 2009 | 1998 Chevrolet Malibu
NO POWER
you may have a draw on the battery.You need to make sure battery is not completely dead and go from there.
Sep 01, 2009 | 1998 Audi A4
Battery is completely dead on my 2000 Porsche 911 C4
on this car you will have to use a batt connected thru the fuse panle you will need to power the side of the panle with the hood fuse then all you will need to do is open the hood
Mar 15, 2009 | 2000 Porsche 911 Carrera
Keyless remote wont work, vehicle completely shut down
Hi Russell,
Absolutely no power? No dome light? No head lights? Nothing?
When you step on the brake pedal, no brake lights?
If true, start at the source and pop the hood.
This is going to be a bit of back and forth dialogue. I'll ask some questions and you get me the answers. That way we can get to the root of the problem. To save time, I'll ask multiple questions at a time. Here goes.
  • Check the battery. Is it still there? (Valid question with no evidence of power)
  • Are the terminal clamps tight?
  • Are the terminals clean and free of corrosion?
  • Are all the belts in place and tight? (pay special attention to alternator)
  • If you have a voltmeter. test the voltage at the battery terminals. It should be +12.5VDC.
Try getting a jump, when the cables are attached does anything light up?
Does it turn over and start?
Does it do anything?
Comment me back with your findings
Mike
Jan 05, 2009 | 2002 GMC Yukon Denali
'91 Honda Accord LX transmission light on.
You say "standard transmission?" Do you mean "standard" as in "manual/5 spd./'stick-shift'?" transmission?
Either way, if you replaced the alternator belt and the battery light went away and the car doesn't sputter or stop, then it's the "speed sensor" on the transmission itself. The car will still drive, but the speedometer cannot read how fast the car is going (in RPM's as well).
Dec 05, 2008 | 1991 Honda Accord
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
