Question about Jenn-Air JCD2389G Side by Side Refrigerator
Whirlpool model # ED5PHEXMQ00 does not get water to ice maker but does to water dispenser
Water dispencer works, ice maker does not work. Why?
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Posted on Apr 05, 2008
  • 150 Answers
SOURCE: Ice Maker does not fill with water
water valve or the ice maker is malfunctioning and not calling for water
Posted on May 07, 2008
  • 1214 Answers
SOURCE: my kitchenaid model kscs25ftms02 water dispenser doesnt work
There is a water valve located at the bottom back of the refrigerator that may have failed or is clogged with trash from the water line. Either is a common problem.
If your know how to use an ohmeter and simple tools like a screw and/or nut driver, I can give you additional instructions on how to troubleshoot. Otherwise, I can search for the P/N and you can order one. You will need to install, or find someone to install for you.
It could also be a filter problem if yours has a filter, or a water supply problem (have you checked the valve a the wall to make sure it was open?).
Posted on Jan 14, 2009
woodchuck789
  • 4070 Answers
SOURCE: Water dispenser stop working? ice maker is fine.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there it’s a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Oct 08, 2009
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
My side-by-side Whirlpool Gold is not making ice.
could be bad solinoid, only letting water to dispencer, u could switch sol leades to see if water goes to ice maker, but check ti make icemaker is on first
May 29, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker is not getting water supply but water dispenser works
the fill valve for the ice dispenser has gone bad there are two separate fill valves for the water dispencer and the ice maker
Sep 20, 2009 | Refrigerators
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
Ice maker not working ; water dispenser ok
The reason could be several different possibilities. the water control valve for the ice maker no longer works or one of the many components inside the ice maker is needing replace or adjusted. Go to link below and enter model ED5VHGXM into model search. Click on photo #12 ice maker and you get a breakdown of of all the parts. Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
Ice maker
I have kenmore two door fridge. My icemaker is not working but the water dispenser is. Model#DU800DWGQ1 Serial#FJ1814737
May 14, 2008 | Refrigerators
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
21 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
