Question about Motorola Cell Phones
Parameter 00 18
Just put time on my phone now told unregistered sim with parameter 00 18 when you put in *#0 at code entry mode, however during boot up it telling me service ends in 30days
  • Official Brand Answer
  • 3,100 Answers
Contact service provider.
Mark
Motorola Support
Posted on Jan 11, 2015
Bajanguru
  • 7752 Answers
SOURCE: NEW RAZOR PHONE NOT WORKING
you seem card does not seem to be active that is the only way you will get that prompt of unregistered sim.
So contact your mobile provider and query your card
Posted on Jun 10, 2008
asood23
  • 200 Answers
SOURCE: how do i register my net 10 sim
Your PUK code is blocked because you have entered wrong code more than 10 times and now you have to replace your sim card. This sim will not work now. Contact your network provider, they will issue you a new sim card.
Posted on Sep 22, 2009
RareSwag
SOURCE: my phone is displaying prepaid services disabled
i had the same problem i was pissed but heres the solution that helped me.
1. go to www.tracfone.com
2.then go to service & support and click on technical support
3.then enter your phones serial number in the "Report Technical Difficulties" box.(to get your serial number go on your phone hit menu,then hit prepaid,then hit serial number.)then hit submit.
4.then once you hit submit scroll all the way down to "prepaid disabled unit disabled".
5.then click contiue once you get there then just follow the steps along the way.
hopefully this works for you
Posted on Nov 08, 2009
dazzle_mps
  • 18 Answers
SOURCE: my phone says unregistered sim my sons phone has
it could be a old sim that has been unregistered or the phone could be repoted lost or stolen but try a active sim 1st
Posted on Jan 20, 2010
SOURCE: i have an LG 290 c straight phone and i
So here's what i did. I have the LG 290c phone from Straight Talk and one day I was messing with the code entry mode and somehow accidentally disabled my phone service. I could receive calls, but not answer them. Same with texts, I could receive texts, but not open them to see the full message.
I called the support phone number (877-430-2355) and they were able to solve the issue relatively quickly. Here's how:
1. Make sure the disabled phone is your active Straight Talk phone. You can do this by going to http://www.straighttalk.com/ and selecting SUPPORT --> PHONE UPGRADE. From there login with your username (email or phone number) and password.
2. On the following page enter the serial number of the phone that is disabled. (You can find the serial number by going Menu --> Prepaid --> Serial Number. Then type in a nickname for that phone.
PS if the disabled phone is already your default phone used, then skip step 2.
3. Go back into the code entry mode (Menu --> Prepaid --> Code Entry Mode) and type in the following code:
894787043481494356609069
After entering that code select OK (a message should appear saying successful entry) and your phone will reset. You're almost done...
4. Go back into the code entry mode (Menu --> Prepaid --> Code Entry Mode) and type in the following code:
66688159611908453214925
Again, after entering that code, select OK (a message should appear saying successful entry) and you phone will once again restart. After the restart, walla, your phone should be back to normal.
Hope that helps. If for some reason you do not see the code entry as being successful, then your best bet is to call their customer service and have them walk you through it...probably entering different codes.
Let me know how it all works out....
Thanks,
-Blum
Posted on Apr 29, 2010
Why does humidifier function shut off after 45 seconds?
bacause of the following reason
.Timing defrost by turning off:
When defrost sensor temperature defrost temperature (Parameter F2) and at the same time the defrost
interval time reaches the set value F3 then can enter to defrost, the fan will turn on, the compressor and
heater will turn off.
After worked a defrost interval time (Parameter F3) time, it will enter the stop mode automatically and
compressor will turn off.; after a defrost time(Parameter F1) will exit the defrost mode and enter to
automatic temperature control mode.
Mar 05, 2015 | Humidifiers
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
Code Error0x0000073
found this on net
STOP: 0x00000073 (parameter, parameter, parameter, parameter) CONFIG_LIST_FAILED
Explanation: This is a Windows 2000 Executive character-mode STOP message. It indicates the system configuration link list failed. One of the core system hives is corrupted or unreadable, or some critical Registry keys and values are not present.
User Action: If this is the first time you have booted after installing new hardware, remove the hardware and boot again. Check the Microsoft Hardware Compatibility List to verify that the hardware and its drivers are compatible with Windows 2000. For information about the hardware, contact the supplier. If you are installing Windows 2000 for the first time, check the Windows 2000 system requirements, including the amount of RAM and disk space required to load the operating system. Also, check the Hardware Compatibility List to verify that the system can run Windows 2000. If Windows 2000 is loaded and no new hardware has been installed, reboot with recovery options set to create a dump file. If the message continues to appear, select the Last Known Good option when you reboot. If there is no Last Known Good configuration, try using the Emergency Repair Disk. If you do not have an Emergency Repair Disk, contact your technical support group.
Nov 19, 2013 | Computers & Internet
Inverter KEB COMBIVERT F5 parameter
The manual that came with the inverter has instructions on how to go from mode to mode.
If you do not have the manual, these can be downloaded from the KEB web site.
Jul 21, 2013 | Inverter KEB COMBIVERT F5
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
How do i get rid of the KERNEL_STACK_INPAGE_ERROR on my d600? Occasionally it says UNMOUNTABLE_BOOT_VOLUME instead. Help?
This issue can occur if a requested page of kernel data could not be read from the paging file into memory, or the master boot record is infected with a virus. To further determine the possible cause, you must properly interpret the error message. If both the first and third parameters are zero, then the four parameters are defined as:
  1. 0 (zero)
  2. Page Table Entry (PTE) value at time of error
  3. 0 (zero)
  4. Address of signature on kernel stack
If either the first or the third parameter is not a zero, then the following definitions apply:
  1. Status code
  2. I/O status code
  3. Page file number
  4. Offset into page file
If this is the case, the cause of this issue may be determined from the second parameter (the I/O status code) by using the following information that is listed in a "value of second parameter" followed by "general cause" format:
0xC000000E, or STATUS_NO_SUCH_DEVICE: the drive went unavailable, possibly a bad hard drive, disk array, and/or controller card.
0xC000009A, or STATUS_INSUFFICIENT_RESOURCES: lack of nonpaged pool resources.
0xC000009C, or STATUS_DEVICE_DATA_ERROR: bad blocks on the hard disk.
0xC000009D, or STATUS_DEVICE_NOT_CONNECTED: bad cabling, non-termination, or the controller is not able to obtain access to the hard disk.
0xC000016A, or STATUS_DISK_OPERATION_FAILED: bad blocks on the hard disk.
0xC0000185, or STATUS_IO_DEVICE_ERROR: improper termination or defective cabling of SCSI-based devices, or two devices attempting to use the same IRQ.
To resolve this issue, use the appropriate method:
Boot sector virus loadTOCNode(2, 'resolution'); To determine if you have a boot sector virus, run a current virus-checking program, and if needed, disinfect your computer.
Not a boot sector virus loadTOCNode(2, 'resolution'); View the System Log in Event Viewer for additional error messages that help you determine the device that is causing the error.
Bad block. Stop 0x77 is caused by a bad block in a paging file, or a disk controller error, or in extremely rare cases it is caused when non-paged pool resources are unavailable.
If the first and second parameters are 0, then the stack signature was not found in the kernel stack. The cause of this issue is defective hardware. If the I/O status is C0000185 and the paging file is on a SCSI-based hard disk, you should verify the disk cabling and SCSI termination.
If the I/O status code is 0xC000009C or 0xC000016A, this normally indicates that the data could not be read from the disk due to a bad block.
If you can restart your computer after the error message, Autochk runs automatically and tries to map out the bad sector. If for some reason Autochk does not scan the hard disk for errors, manually start the disk scanner. If your computer is formatted with the NTFS file system, run Chkdsk /f /r on the system partition. You must restart your computer before the disk scan begins. If you cannot start your computer due to this issue, use the Command Console and run Chkdsk /r.
Defective or unreliable random access memory (RAM) is another common cause of this issue.
Verify that all the adapter cards in your computer are properly seated.
Ensure that all adapter card contacts are clean.
Disable system caching in the BIOS to see if this resolves the error.
If this does not resolve the issue, your computer mainboard may be damaged.
Oct 23, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Icorrect parameter on startup
Hello , This is Registry or domaged entry in any application can cause this problem so Better your Registry optimizer like CCleaner Hope it will help :)
Apr 06, 2009 | Dell Dimension C521 PC Desktop
I am getting the C2664:Can't convert parameter 1 to LPCSTR
Parameter 1 is probably not a string. If fact based on the code snippet it looks like parameter 1 "sring1" maybe should be spelled "string1"
Feb 24, 2009 | Microsoft Visual Studio 2008 Professional...
Faxing
I was able to get my psc2410 to receive faxes by changing the baud rate to 9600. I still have an issue transmitting. Here are the instructions to do so:
1. Press * and # at the same time, and then release both keys.
2. Press 1, 2, and then 3, releasing each key before pressing the next.
3. The display window should read "Service" with a revision number.
4. Press the right arrow button once.
The display should read System Configuration or r/w parameters. Press Enter.
*** If it shows r/w parameters at step 4, go to Step 6 or follow next step.
5. Press the right arrow button until r/w parameter appears in the display. Press Enter.
6. The display should read parameter 0.
7. Press 153 on the keypad to go to parameter 153. Press Enter. Change the value to 2 and Press Enter again.
*** The display should again read parameter 0
8. Press 159 on the keypad to go to parameter 159. Press Enter. Change the value to 2 and Press Enter again.
*** The display should again read parameter 0.
9. Press Cancel until you reach the date and time screen on the Panel again.
This should reduce the fax transmission speed.
Jul 10, 2008 | HP PSC 2410 All-In-One InkJet Printer
Cell Phones Logo
16 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
