HP Power Assistant "no battery detected" - Computers & Internet
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
HP4530s battery dischargs when turned off
Remove the battery when the laptop is OFF. I am not good at electronics, but I think this is normal and is NOT A PROBLEM.
Jan 20, 2013 | HP ProBook 4530s Notebook
Hp power assistant installer
Your OS file is missing, so install it again & install a update version of power assistant.
Apr 19, 2012 | HP ProBook Computers & Internet
What's your problem? power steering
Then it detected a overloead,or low battery output,if the steering wheel is held in a maximum position for a extended time the PSCM will go into overload protection mode to prevent damage to the system, you may notice normal amount of assistant return after normal steering movement
Mar 03, 2012 | 2006 Chevrolet HHR
Does not detect power
if your printer does not detect power, it might be the power cable itself cannot carry the power from the outlet to your laptop. Try insert another power cable of that kind. If your laptop does not have any battery to back it up, you might call HP to replace a power cable on your printer..
Nov 21, 2010 | HP PSC 2210 All-In-One InkJet Printer
The laptop will only work on the mains cable
perform battery health test according to the operating system you are using.
for vista:
1. Click on start or windows logo (pearl) button.
2. Click on HP Help and Support.
3. Click on troubleshooting steps and then Battery.
XP:
Please run the following softpack on your notebook to check the battery health:
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32299.exe
Windows 7:
1. Click Start and select HP Support Assistant .
2. On the HP Support Assistant window, select Troubleshoot , and then select Power, Thermal, and Mechanical .
3. Click Battery Check to examine your battery and display the results of your battery status check.
The current state of the battery (charging or discharging) is displayed.
Then you will be knowing what the exact issue is. If the battery health test fails you can replace it.
May 13, 2010 | HP Compaq nx6110 PC Laptop
Hp wireless assistant problem
Is your wireless network working fine? If yes, it is better to close HP Wireless assistant program as windows has inbuilt program to detect the WIFI connections. You can type "msconfig", go to startup and close the required process. It should stop.
Feb 16, 2010 | Compaq Presario Notebook
Netbook is not charging
Since its a new system and i believe that you have a warranty for that i suggest to bring your laptop to the store where you bought it to check the battery and i'm sure that the battery is defective.
Oct 01, 2009 | Advent Netbook
Hp wireless assistant 3.00 C2
You may install a different version but it is not guarantee that it would work. I suggest to connect your system to an ethernet cord (wired connection) then click on the link below..
http://tinyurl.com/6jlcth
You should see there Start Detection - it will automatically detect the system driver you have. You should select the operating system then you may reinstall the network driver then.
Keep me posted.
Thanks
Nov 20, 2008 | HP Pavilion dv6000z Notebook
hp support page let them detect ur laptop aand they will give u everything u want
Aug 16, 2008 | Compaq Presario Notebook
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
