Question about Toshiba 40RV525U 40 in. LCD TV
Screen problem screen hit and doesn't show picture
Dx2200 stops booting up. then shows a purple and yellow dotted screen !!! why ?
If your screen shows a clear picture to start with then it is most likely the video card driver. I don't know what you mean by no access to safe mode, but if you can get into safe mode you should be able to uninstall the video driver and restart. Safe mode is usually accessed by hitting F8 before windows starts so as soon as you see a picture on the screen start hitting F8 a few times until you get to the safe mode selection menu.
Dec 16, 2013 | HP Compaq dx2000 Microtower PC Desktop
My camera doesn't work
You have to format your sd card
Jul 09, 2013 | Cameras
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
I have a 20F42OT - is there someway to change the screen so the entire picture shows? for example, if there are sports scores on the bottom of the screen, you can see only top half. Screen should be...
does the remote have a aspect button? or maybe it is in the menu? If not let me know and I'll look it up. I have worked on some of these but dont remember them being wide screen
May 03, 2011 | RCA 20F420T 20" TV
37" full hd philips tv screen cracked because
If there is picture in the TV then probably it is the protective screen that has cracked and not the picture tube.Please check carefully.
Jan 20, 2011 | Philips Televison & Video
Display screen is not showing up
There is a setting which controls how long the picture you have just taken will be displayed on the screen. Maybe adjusting this will help? I hope so.
Jul 15, 2010 | FUJIFILM FinePix S1800 Digital Camera
Does not show the picture on screen right after picture is taken
It does not show the picture after you take it. You have to hit the home button and hit playback. Annoying, I know!
Jul 28, 2009 | Vivitar ViviCam 8025 Digital Camera
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08
i have the same problem with my camera it show 5foa 5f08 5e02 with the blue screen
Sep 24, 2008 | Olympus Stylus 710 Digital Camera
Toshiba 40RV525U 40 in. LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
