Question about Dell Inspiron 6400 Notebook
My cds will start to 'run' on disk drive but it will not run or open/load them so that i can install or play sims or football manager ect
  • Dell Master
  • 32,281 Answers
Some CDs do not autostart. it depends on how they are setup.
If you have a games CD and it doesn't autostart then click on My Computer and then the CD drive (your could be the D drive) and double click on the Setup or Install file. The program should then install on your computer.
Posted on Jun 18, 2009
I have trouble loading CDs. There is a place to
Make sure you are placing the CDs in the drive with the label side up. If the computer can read DVDs, it can certainly read CDs as well. Once the cd is inserted, wait and the autoplay should start the installation program for the software.
Dec 01, 2009 | E-Machines eMachines T3830 PC Desktop
Try to load th game and not well formatted (invalid token)on last saved game parsing error then i click ok and fm 2009 dissapears
Okay, please repeat the problem and symptoms, that was a bit out of sorts.
This is what I got:
You were trying to play Football Manager 2009, but when you loaded up the game, you got error code "invalid token."
if so;
You need to clear your cache files. Do this without the game running.
How to delete your Cache files
First of all you need to turn on hidden files and folders. Go to My Computer and at the top select 'Tools' the 'Folder Options'. The go to the 'View' tab and select 'Show hidden files and folders'
Windows XP:
1. Open “My Computer”
2. Navigate to : “Documents and Settings\<Username>\Application Data\
3. Go into the “Sports Interactive” Folder.
4. Go into the “Football Manager 09” Folder.
5. Delete the folder called "Cache"
Wndows Vista:
1. Click “Start”
2. Click your username on the start Menu
3. Click on “AppData” and then “Roaming”
4. Go into the “Sports Interactive” Folder
Mac OSX
1. Open Finder.
2. Select <User>
3. Navigate to Library\Caches\Sports Interactive
5. Delete the "Cache" Folder.
5. In the 'Library' Folder look for the 'preferences' folder.
6. Go into the “Football Manager 09” Folder.
7. Delete the "Cache" Folder
Do NOT Delete the folder marked "Football Manager 2009 Certificate".
Oct 11, 2009 | Video Game Consoles & Games
It doesn't recognize/read/play cds or dvds that
Hello there:
first off i would go to device manager and open it and look for the area that says disk drives and open it and look for your cd/dvd right click on it and select remove than confirm removal of the device now at the top of the page you will see view and click on it and where it says scan for hardware change select that and then windows will install the device again you will see new hardware found on the taskbar and it will tell you when the device has been installed and is ready to be used. ok?
i hope that this information is very helpfull for you
please rate this information i have provided for you ok?
best regards mike
(USN RETIRED)
Aug 04, 2009 | HP Disk drive - CD-RW / DVD-ROM combo -...
My pc wont open football manager 2009 disk
click on the diskdrive that fm is in once to get the pop up menu and click on open auto play and then click onto open folder and in that folder there should be the application to install football manager 09
Jul 04, 2009 | Video Game Consoles & Games
Im having problemx installibg sims deluxe edition
Dear mz_bridg_ett,First of all you need to check that your computer hardware/ the entire computer meets the specifications of the game. you will be looking at things like
CPU speed -- the higher the number in MHz you have the better
RAM speed -- this is your computers' memory, the bigger the number in MB/ GB and MHz the better
HDD size -- this is your hard disk drive, bigger the number in GB the better. . . . typical size is 120-500Gb and will be enough for the game . . . . . . more than enough even with Windows (EWWW YUCK!! ) installed on it.
GPU speed-- this is your graphics disply, and like the rest, the bigger the number the better, best to check out your specifications before you attempt to play the game.... ideally you want a direct x 9.0c card or better still direct x 10 when in windows (YUCK) go to start>run>command>dxdiag ... this will check that for you
Right with that lot done, open your CD drive, and put the install disc into the drive, and it should start to run automatically. . . . if not go to my computer and find the CD drive letter and double click it. . . . . if you are a smarty pants like me, then you can go to start>run>command>X:\autorun.exe...........substitute value "X" for your drive letter, you can also type....start>run>command>X:\setup.exe..... for Vista (awwww ewww awful) then you need to go start>all programs>accessories>command prompt> command.com...... then follow the above for other version of windows.
game should start to load, ask you where you want to install it, and then for the password/ product key of the game, which you can find on the back of the manual or on the reverse inside of the CD case.
enter the code then hit ok
When this is done, itll ask you to enter the game disk/ play disk if you dont have to reboot your computer, but i always reboot first anyway.
enter the play disk and run it like you did before with the install disk, unless you are one of the many masses that add shortcuts on your menu and systems to start up your programs/ warez.
if this doesnt work, try cleaning the disk, try installing it to different locations, even get diagnostic tools to check your computer. . . .
definitely try all above before feeding the game disks to the dog.
I hope this is the fixya for you
yours sincerely
Oz
Mar 13, 2009 | EA - Electronic Arts The Sims Deluxe...
My Football manager 2009 disc won't load up
Try to look for patches and updates of the program, ormaybe your drivers are old, or not compatible at 100%.
Try thease.
Feb 22, 2009 | Microsoft Windows XP Professional With...
Installing the sims 2 double deluxe
Does your laptop have a DVD drive? It is likely that the Sims Double Deluxe disk you have is a DVD ROM and not a CD ROM.
If this is not the case, try clicking My Computer and selecting the CD drive to see if the computer recognises the disk at all. Run setup.exe if it does.
Feb 04, 2009 | EA - Electronic Arts The Sims Double...
Macplay baldurs gate 2 disk ejects before loading
I manage to start the game on Mac OS X Leopard. I have burn the CDs (CD 2 - 3 - 4, because you need them to play) and than, to solve the problem of "ejects of the disk" I have also mounted the image dmg. Then to start the game I insert the CD 2 for example, then I mount the disk image dmg (the same that I have burn on the CD) e then I open a file .bif in the folder CD2/Data/
The computer open this file and start the game!
Gimmy
Dec 28, 2008 | Macplay Baldur's Gate II: Shadows Of Amn...
Football Manager 2009 won't play
you need to run a full recovery on the system
Dec 27, 2008 | Microsoft Windows XP Professional With...
Can't read, burn cds
have you tried different cds? or just 1 same cd?
Oct 19, 2007 | Compaq Presario 5000 PC Desktop
Dell Inspiron 6400 Notebook Logo
43 people viewed this question
Alun Cox
