Question about Krups Coffee Makers & Espresso Machines
Krups XP7200 water fill light flashing - Krups Coffee Makers & Espresso Machines
2 Suggested Answers
SOURCE: Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Posted on Sep 27, 2008
The red light comes on and then goes green. Filled with water and pod in but nothing happens. Completely silent.
one step at a time do you get water with out putting the capsule
what is it doing is there any sound coming from the pump do you have any flashing red light? need more info
Jan 11, 2016 | Krups Dolce Gusto KP 2100 Espresso Machine
Krups KP2100
satzo software did not hacked any account why
Jan 30, 2014 | Krups Dolce Gusto KP 2100 Espresso Machine
Krups xp7200 how to do descaling
Manual has procedure....read that section.
Jan 24, 2013 | Keurig B50 Coffee Maker
My krups xp7200 is leaking water from the bottom. How can I open it to check the problem? thanks
You need to unscrew 4 screws in the front, three on the top (underneath the lid where you put the cleaning tablet), one inside the coffe container at the top, and pull gently, but firmly the little black nob inside the coffe container, that you use to adjust the coffee grinding, straight up. Then you can remove the coffee container on the top, and unscrew one screw underneath this container. Also, remove the two screws from the holes beneath the water container. NOW, you should be able to pull the front electronics off, and pull the main cover backwards, away from the front panel. You may have to bend it a little to get it completely off, but it is not a problem. Good luck! :)
Jun 15, 2010 | Microwave Ovens
Krups XP7200 series date problem
It seems that the dial knob and the electronic opto coupler don't work anu more. You can replace the digital panel by try to find a broken machine on ebay. Unless you are an electronics engineer like me (you can try to replace the optocoupler). See the post on leaking xp7240 for opening up the machine... it's tricky but easy.
Apr 14, 2010 | Krups XP7230 Compact Super Automatic...
Krups XP2070 Stops putting water through after a few seconds and screen flashes and on/off button flashes. Does this when head is removed and descaling too. It will start to flow once switched off/on and...
Most likely a faulty flow meter unit which is not providing the right information to the control unit. Replacing is not too difficult and the replacement meter is < $20.
Nov 01, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP7200 wont grind beans (all lights flash)
See post on leaking xp7240. It is almost the same machine. This post explains how to fix it (valve is blocked but can be easily cleaned)
Mar 14, 2009 | Krups Small Appliances Espresso Machine
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Jan 19, 2008 | Krups Orchestro 889 Espresso Machine
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
