Question about TDK Electronics - Others
Data recovery flash is write protect i cant format it.
2 Suggested Answers
  • 70 Answers
SOURCE: format 4gb transcend flashdrive JFV10. " WRITE PROTECTED"
plug in pendrive right click on it
click on properties
go to tools
and click on backup now
Posted on Apr 20, 2009
Hard Drive RAW System
Run diagnostics on the drive it may be failing. If it's ok you can try to reformat it from Windows Disk Management.
Or if you need to recover data for remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 11, 2012 | FireLite (USBFLB80) Hard Drive
I have A-data my flash 8GB usb which write is protected please tell how i can Fix it ,,when i try to format the usb it say windows was unable to complete to format
The problem isn't with write protection. The file system has become corrupt and unreadable, or at least a section of it. If you can't reformat it then it's likely dying or dead. At least you should be able to recover some of your data however...
Go here and get a FREE copy of USB Flash Drive Data Recovery Software:
http://www.easeus.com/resource/drive/usb-flash-drive.htm
May 15, 2012 | Electronics - Others
The disk in write protect
When formatted, the disk is write protected (there is damage to firmware)
Damage to firmware, there are two types
1. Damage to firmware, data can be saved
2. Damage to firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair Damaged and repair firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Dec 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend 4 gb pendrive is write protected .how can i remove the write protection
When formatted, the disk is write protected (there is damage to the firmware)
Damage to the firmware, there are two types of
1. Damage the firmware, data can be saved
2. Damage the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and repair the firmware.
Nov 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a 500GB WD my passport essential external hard disk. Previously it works but few days back when i plug on my laptop. It does detected by my laptop but it doesnt show in windows explorer. When i...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Jul 06, 2011 | Western Digital My Book Essential Edition...
The Computer cant open the USB Flash Drive. It said that it is not formatted so I try to Format the Flash drive via command prompt. The command prompt said "The first NTFS boot sector is unwriteable....
It should be the file system problem. Usually a usb drive should be formatted to FAT initially instead of NTFS. Recommend you try the USB on another computer and see if the problem still occurs. If yes, then try format it from Disk Management of your computer. If you can't format, use TestDisk (also a command line tool) to fix the file system error. You can also see from this blog post to learn more about the possible reasons or solution. Regards
Jun 14, 2011 | Computers & Internet
My usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
Cant Format pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 01, 2009 | Transcend (589307) Media
Format 4gb transcend flashdrive JFV10. " WRITE PROTECTED"
click on properties
go to tools
Apr 12, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Electronics - Others Logo
24 people viewed this question
Top TDK Electronics - Others Experts
Alun Cox
 Grubhead
Grubhead
Sandy Moore
Sandy Moore
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
