Question about Sega Master System Console
Why are there vertical lines on my sega master console
There are vertical lines on my tv when i am playing whit my sega master console
probably av cables..check them at console and at tv end...if still doin it..find new av cables ..good luck
Apr 16, 2014 | Sega Master System Console
Where could I find a replacement controller port for my Sega Master System, one of the pins is broken, and I would prefer to replace it without cannibalising any of my other consoles.
The best place to look for things like this is eBay. Just search for As-Is Sega Master System on eBay, and see what comes up ( I also just searched for sega master system, and found some cheap consoles that were in working order). Also, another option you might try is see if there were any "controller extensions" made for it. That might give you something to cannibalize to make your new port. Hope this has helped!
Feb 25, 2011 | Sega Master System Console
Black and white Picture Sega Master System 2
Is this one of those much older Sega systems with the RF connector that plugs into the incoming cable from outside and the TV?If it is,there should be a channel selector switch on the back,CH3 or CH4.Try the other channel.If it doesn't go away,your RF connector is on it's last legs.
Good luck and game on!
Jul 26, 2010 | Sega Master System Console
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Jan 30, 2010 | Sega Master System Console
Game master
try researching it
Jan 05, 2008 | Sega Master System Console
Sega master system
You need an RF Switch. Any kind will do. Sega model 3035 came with your console. Sega model 1603 or Nintendo NES-003 will also work. The RCA plug goes in the back of the console and the lead that looks like cable tv goes on the tv. If your tv does not have the right connection you can purchase an a/v cable that will work.
Oct 20, 2007 | Sega Master System Console
Sega Master System Console Logo
15 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
