Question about Dryers
Need wiring diagram for 1.5 hp single phase 3450 rpm marathon motor 6 leads - red yellow brown black black green
SOURCE: I have a 4 leads
White goes in the middle and green is your ground there should be a spot on the cabinet too too attach the green ground wire.
Posted on Jul 10, 2008
  • 1383 Answers
SOURCE: rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: wiring diagram?
They ain't power leads. They carry heat element current from the cent sw when the motor is running.
Posted on Jan 10, 2009
  • 96 Answers
SOURCE: Need connection diagram, AO Smith motor FDL 1056
Black is high , Blue is med. , red is low
Posted on Feb 19, 2009
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
Need wire color diagram
Black = AC hot
Red = switched AC hot
Yellow = AC hot from a another source - another control panel as an example.
White = neutral
red w/white tracer = switched neutral
Green or green w/ yellow tracer = ground/earth ground
blue = DC voltage, ie, 12vdc, 24vdc
white w/blue tracer = dc common
Brown = AC 3 pahse - phase A
Orange = AC 3 pahse - phase B
Yellow = AC 3 Phase - phase C
shileds: think of current loops
2 cond
clear or red = +
black = -(neg)
3 cond
red = power (24vdc typically for transducers)
clear = + (signal output)
black = - (signal common)
Hope this helps, oh, and any panel I have design and wired this way is easily understaood by 99% of all service and electrical people I have worked with.
Apr 15, 2015 | Cars & Trucks
How to wire for 220 v
220 is two hots and one ground. If it were me I would leave red orange and white "together",then verify your voltage on remaining wires. 110, 110, 0. If not, youre no good. Try something different. It doesn't matter what "line" goes to what "load" just as long as one of these goes through whatever relay/switch you are using. Good Luck. Hopefully single phase. If motor runs backwards swap wires.
Mar 14, 2017 | Heating & Cooling
Old motor wires are numbered new motor wires are colored this is a 1/2 hp reversing motor for a overhead door
Single Phase Terminal Markings Identified By Color: (NEMA Standards) 1-Blue 5-Black P1-No color assigned 2-White 6-No color assigned P2-Brown 3-Orange 7-No color assigned 4-Yellow 8-Red
Mar 02, 2014 | Computers & Internet
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
I have a gmf electric motor and it has 4 wires .. blue brown black and yellow/green .. is this a 3 phase motor and if not how would it be wired into a single phase circut?
No it is a single phase motor the different wire colors are the different speeds brown would be common and then black is high, yellow medium and blue low and green is ground.
Mar 12, 2010 | Heating & Cooling
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Rewiring mootor from 230v down to 115v
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
