Question about Sony Audio Players & Recorders
Can upconversion really convert 480i to 1080p
Regarding the Sony DG920 Home Theater 7.1 Receiver, specs say it will do upconversion to 1080p from any video source. Does that include 480i coming from standard TV via cable box, the signal coming from a VCR, or standard dvd?
  • 1 more comment
  • fletchone3 Jun 18, 2009
    Your opinion is the opposite of the other "expert". Based on your conclusion, the specs that Sony provides are not true. They imply any source (cable box, vcr, dvd, ldp) can be upconverted within the unit and output via HDMI to the TV. From that I would think the conversion takes place in the unit but I'm not sure. That's why I'm asking. I don't want to spend $500 for a unit and it doesn't do what Sony implys.
  • 10,594 Answers
Sony claims that STR-DG920 is equipped with conversion / up scaling of video signal to get output from HDMI or Component Video.
You can check this video up scaling function in nearest Sony Store as this unit would be on display / demonstration.
Click Sony Support to download user manual copy to get to know more details on page-31
Thanks.
Posted on Jun 18, 2009
This would be unlikely. The upconversion usually takes effect if connected via the HDMI cable. So if you're connected with HDMI and getting 720p from the source, it can upconvert it to 1080p. But if you're getting images from a source other than HDMI, it will display as the source without the upconversion.
Hope this helps.
Regards
nLinked
  • Sony Master
  • 13,433 Answers
Yes it will convert anything to 1080p the end result will be effected on the quality of the source.
Yes I believe it does include 480i, cable box, vcr and dvd players.
I keep gettin "no TV Signal" on my Emerson EWL20S5C when i plug in a indoor tv antenna. DoI need a converter box. I live very close to tv towers. HD
I cannot seem to find info on the version "C" model, but everything I find on the base model appears that is is not a digital unit and does not have a digital tuner. Thus it would need a converter box to tune digital HD channels. That said, the specs also say that the set can handle 480p/480i/1080i inputs. Thee is no mention of 720p/720i/1080p capability, which funnily enough, most US TV HD broadcasts are in 720p or 1080p. You may find you need a new set.
Jul 25, 2016 | Emerson Televison & Video
How do I connect audio from HDTV to Sony STR-DE615 Home theater receiver as it has outdated connections
You maybe able to get adapter/converters to suit, if not get a savy friend to make up cables to suit your TV/Sony.
Dec 13, 2012 | Sony STR-DE615 Receiver
My Sony STR-DG920 shuts off then comes back on by itself every 4-5 minutes. It very quickly loses power then comes back online. Any ideas what might be the problem?
The problem is the Power Switch. The switch on the STRDGF920 is very problematic. When the receiver is on very lightly move around the power switch with your finger. do not use enough pressure to turn the unit off. Just very lightly slide your finger over the switch and you will see your problem happen. I have two STRDG920 units with the same problem. One is so sensitive I can blow on the switch and it will power cycle off and on. I have called Sony and they said they do not offer a replacement part power switch. I will have to figure something out.
Aug 08, 2011 | Sony STR-DG920 7.1 Channels Receiver
How do we set the picture to 1080 megapixels from 480i?
U can't just do it on ur own setting like 480i to 1080p when ever u want.No,u only get what ever the tv stations modes they set and send out only.Ur tv have the 1080p mode capability mean ur tv can pickup that 1080p mode.Dosen't mean u can change 480i to 1080p by ur self anytime u want,if the tv station is broadcating tv signal to u only in 480i u get only 480i.
Jun 23, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Dec 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a Yamaha HTR-5440 receiver and I want to connect it to my Directtv Plus HD DVR satilite receiver what do I need
If your yamaha receiver has Hdmi upconversion and HDMI pass through you should only need an HDMI cable. One from the directv receiver to the Yamaha Receiver and another from the yamaha receiver to the tv. If it does not have HDMI then you'll need component video cables and 1 optical cable.
Oct 23, 2009 | Audio Players & Recorders
I have a new Sony Bravia KDL-26L-5000 with Directv and the image is pixelated. Can I do anything?
Make sure you have subscribed to a HDTV service with your television provider.
Also, make sure that all of the devices that are connected to your television are HD devices, connected with a HDMI cable, not a coaxial or RCA jack.
HDTVs aren't magical TVs : everything from the source to the television, including your home theater and PVR, if any, must be HD-compatible in order for the picture on your screen to be in high definition.
On BRAVIA screens, I know that, when you select an input, it will briefly show the definition of the source in the corner of the screen. You must make sure it's 1080p. If it's anything other than 1080p, your picture is not in HD.
I remember that my grandparents had a similar problem. It turns out their BRAVIA television was displaying a low quality picture (480i), even though they had subscribed to a HDTV service, just because their satellite receiver was not configured correctly.
So maybe the solution is simply to make sure that each of your devices is configured to display only the highest resolution available (usually 1080p) in order to enjoy the best picture quality. Do not trust "automatic" quality settings, because they tend to select lower quality settings (such as 720p, which is not True HD), when they might be able to display true high definition pictures (1080p).
Jun 11, 2009 | Televison & Video
480i is displayed on the tv even when I play my Sony BluRay
You have to go into the blueray player menu and select the type of output. And, yes the display on the TV will automatically indicate the type signal it receives from the source.
michtech
Dec 03, 2008 | Toshiba 62HM95 62" HDTV
Receivers
If it is me and I am spending that kind of money, it is going to be sick, os here is sick. 7.1 dolby surround and 1080P HDMI, 135W per channel, and right now if you go to FRYS.com, it is normally $500.00 bt for right now it is only $449.00. But if you put this in, be prepared to buy a PS/3 as your next investment (Th best way to get Blu-RaY at an affordable price, plus many other features) and an upconvert DVD layer, which is only about $100.00 or less today. Then you better get ready to hear from your neighbors and the cops, because they are going to think a war has broken out in your place. Enjoy, I play movies that the sound is just so realistic, I hate to leave the house anymore. Also, remember, speaker placement is key, so know the optimal environment for your system and if you need one, I may be able to hook you up with a system room tuning DVD for next to nothing. This will allow you to setup your system and place your speakers optimally for your environment. good Luck.
Onkyo TX-SR606B
7.1 A/V Receiver with HDMI Up-Scalling
Onkyo USA:
FRYS.com #: 5586420
The Progression of Affordable High-Def Home Theater Continues with Full HD Integration and Video Upscaling As part of the second generation of Onkyo high-definition-capable receivers, the TX-SR606 is at the forefront of affordable home theater. The key is to have the most capable version of HDMI. The TX-SR606 provides high-definition video and audio processing for four source components—another first for Onkyo at this level. From Blu-ray Disc players to gaming consoles and cable/satellite boxes, you have everything in the digital realm covered. Apart from 1080p video, the TX-SR606 can upscale all video signals to 1080i, regardless of the connection, for output via HDMI. Onkyo's own RIHD (Remote Interactive over HDMI) also gives you inter-operability with the displays and playback components from other leading brands. And with an expanded version of Audyssey's room correction technology, the TX-SR606 maintains the fullness of surround sound audio quality at low volume levels. The TX-SR606 offers all-round excellence rarely seen at this levelSpecial Features
  • HDMI v1.3a Repeater (4 inputs, 1080P compatible)
  • HDMI Video Upconversion
  • 1080i Upscaling powered by Faroudja DCDi Edge
  • TrueHD, DTS-HD Decoding
Amplifier
  • # Channels 7
  • Power (8ohms 20-20kHz 0.08%) /Ch 90W
  • Power (8ohms 1kHz 0.7%) /Ch 105W
  • Continuous 6ohms Rated
  • High Instantaneous Current Capability 36A
  • Amplifier Frequency Response 5Hz-100kHz
  • S/N Ratio (LINE IN) 106dB
  • All Discrete Circuitry
  • Absolute Ground Plate
  • Optimum Gain Volume
  • Non-Scaling Configuration
  • Bi-amp Capability For Front
Processing
  • DOLBY Decoder DD Plus, TrueHD
  • DTS Decoder DTS-HD Master Audio
  • Direct Mode
  • Music Optimizer
  • Audyssey Dynamic EQ
  • 192K/24 Bit DACs
  • DSP Type / QTY 32 BIT
  • Adjustable Crossover 40/50/60/80/100/120/150/200Hz
  • Independent Crossover
  • AV Sync
  • Accurate Speaker Distance Setting
  • Multi-Band Speaker EQ 5 Band
Connectivity
  • Audio In/Out 7 / 2
  • Digital Audio IN (OPT/COAX) 2 / 2
  • Composite In/Out 5 / 1
  • S-Video In/Out 4 / 1
  • Front-Panel A/V L / R / V
  • Component Video / Bandwidth 2 in / 1 out / 50MHz
  • HDMI In/Out 4 / 1
  • HDMI Version V1.3a Repeater
  • HDMI Bandwidth 1080p
  • HDMI Deep Color Capable (36bit)
  • Analog to HDMI Upconversion
  • 480i to 480p Processing (DCDi Edge)
  • 1080i Upscaling
  • Multi-Channel Input 7.1
  • Surround Pre-Outs SUB
  • Powered Zone2
  • Zone 2 Line Out
  • iPod Ready (DS-A2x, DS-A2, DS-A1)
  • SIRIUS Radio Ready
Integration Access
  • Onkyo-RI System Control
Miscellaneous
  • Pre-Programmed Remote
  • Glossy Black finished Remote
  • Simple Remote to change input & mode
  • Color-Coded Speaker Terminals
  • Auto Speaker Calibration W/Mic. (Audyssey 2EQ)
  • On Screen Display Out
  • Permanent Memory Storage
  • Solid Aluminum Front
  • Warranty 2 YEARS
Oct 13, 2008 | Audio Players & Recorders
90 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
