Question about Carrier Freezer Beverage Air® KF48
I need to replace the door gasket on a Carrier 14K42 Freezer, Serial #650988. Can you suggest a place where I might find this? The freezer is about 35 years old but works wonderfully, except that the gasket has worn flat on the upper right side and therefore is leaking air.
    Sergeant:
  • 340 Answers
Good luck try caseparts.com they can custom make possibly what you .Tom
Posted on Jun 18, 2009
Can I replace insulation in door only?
Hi - I understand that you recently had something heavy drop on top of your Frigidaire Freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 5 cu. ft. / 142 liter Chest...
Condensation on top of freezer. It got something very heavy dropped on it. Dented the top corner. Door seal gasket IS sealing properly. is there a way to re-insulate just the door?
Hi - I understand that you recently had something heavy drop ontop of your freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 13 cu. ft. / 368 liter Chest...
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
Water leaking from under Freezer (frost free).
Thank you for your post, Al!
I understand that water is leaking from under your Frigidaire freezer. This could be a possible issue with your drain line or gasket. I would recommend performing a manual defrost and you can do that by unplugging the power cord for at least three to four hours.
If that does not correct your issue I would suggest checking your gasket and you can do that by using a dollar bill. Place the bill between the door and body of the freezer and shut it. Attempt to pull the bill out if it provide resistance then the gasket is good, if the dollar shows no resistance the gasket may need to be changed. I hope this information is helpful for you. -Matt
May 29, 2015 | Frigidaire Freezer 16.7 cu. ft. Upright...
When I open the refrigerator the freezer pops open
I appreciate your inquiry, Tammy McAninch!
Based off the information you have provided your Frigidaire freezer door pops open when you open your refrigerator door. This can happen with new refrigerators because the seal is new. I understand your question is labeled under model FGHB2866PF. It could be issues with your door not aligned properly and hitting your freezer door to open. I would check the gasket to make sure they are creating the proper seal on your freezer in order to check that you can use a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you continue to experience issues with your freezer door I would recommend reaching out to a professional for further assistance. I hope this information helps to some degree. -Matt
Nov 17, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Freezer not cold. Can't get to coils to see if they are frozen.
Hi grammycather, thank you for allowing me to assist you. Here are a few simple troubleshooting tips that may help you resolve this issue:
First check clearances around your freezer. There must be adequate space around a freezer with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the unit.
Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the appliance. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure freezer is level and keep food and containers from blocking the door closing.
Check the door seal. You do this by placing a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then refer to a tech to replace the gasket.
Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the freezer will not get cool.
I suggest to double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Aug 11, 2013 | Frigidaire 14 cu. ft. / 396 liter Upright...
Change digital thermostat on frigidare freezer
Not hard to do. Just make sure you have it grounded well. Very reliable. Just follow instructions to the tee.
Jan 29, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Why is there Water on floor under my freezer
Hello C. Richard Robinson - Is the door being kept open too long or frequently? If so, try removing the items needed from freezer ahead of time so the door is not open as much. However, main possibly could be a poor door seal. Try checking this by placing a dollar between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If nothing is stopping the door then the gasket will need replacing and adjusting by a professional.
Jan 18, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer has condensation inside
Hi - From what you have described it sounds like the freezer has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Oct 06, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
I need to replace a worn Carrier upright food freezer door gasket
Are you looking for door seals? If so, there are several places that can custom make them. Try calling Restaurant Parts and More at 1-888-814-1110 and talk to Rick. He can send you a cataloge with the different types of gasket materials available. He knows what questions to ask to help get the right one.
Aug 12, 2009 | Carrier Freezer Beverage Air® KF48
Carrier Freezer Beverage Air® KF48 Logo
243 people viewed this question
Top Carrier Freezers Experts
Dennis Boxerman
AJMAL KHAN
Bill Boyd
Are you a Carrier Freezer Expert? Answer questions, earn points and help others
