Question about Casio FX-115ES Scientific Calculator
Calculate the inverse of a 4X4 matrix on fx-570ms
  • Casio Master
  • 7,993 Answers
The Casio FX-570MS does not handle matrices. So you cannot create matrices, let alone invert them. Sorry.
The Casio FX115 ES handles matrices for up to 3X3 dimension. Create the matrix.Have its name displayed on the command line and press the [x^-1] (reciprocal ) key.
Posted on Apr 16, 2014
Casio fx-9750GII is giving the wrong answer, is it broken?
Check the calculator with a simple 2X2 matrix that you can invert by hand easily and see if it gives you the wrong inverse for it. It is also possible that YOU made the mistake.
Jan 03, 2016 | Casio FX-9750GII Graphing Calculator
How to calculate adjoint of matrix in casio
You have the relation [A]^-1 (inverse of A) =Adj([A])/det([A])
Create a square matrix [A]
Calculate its determinant det(A) and store it in some variable (why not D). Calculate the inverse of A. Multiply the result by the determinant.
Jun 12, 2014 | Casio FX-115ES Scientific Calculator
How to find the adjoint of a matrix by scientific calculator
Adjoint of a square (non singular matrix) = product of the determinant of matrix by the inverse of matrix. Adjoint([A])= det( [A]) * [A]^-1.
To get the inverse of a matrix, have its name displayed on command line then press the reciprocal key [x]^-1
May 23, 2014 | Casio Fx-991es Scientific Calculator
Where is the inverse button on the casio fx-82ES
For the reciprocal of a number, enter the number then press the key marked with an x^-1. You might have to use the SHIFT key first. For inverse of trigonometric functions use the SHIFT key followed by the function name. The inverse of LN is e^x. The inverse of log is 10^x. To calculate the inverse of a matrix, enter the name of the (already created) square matrix then press x^-1.
Jan 09, 2012 | Casio FX-115ES Scientific Calculator
Want to calculate the inverse of a 4X4 matrix on a casio 991es
Sorry, this calculator can handle matrices with dimensions ranging from 1X1 up to 3X3 . To deal with 4X4 matices you need a graphing calculator such as the CASIO FX-9570G Plus, the Ti83Plus.
Oct 23, 2011 | Casio FX-115ES Scientific Calculator
How can i calculate inverse of 3*3 matrix using casio fx-570MS
The casio FX-570MS does not handle matrices. So you cannot create matrices, let alone invert them. Sorry.
Feb 12, 2011 | Casio FX570MS Scientific Calculator
How do you use a fx-9750GII calculator and inverse matrix to solve the linear system:\r\n w+x+y+z=10 w+2y+z=7 w+x+3y+z=8 w+x+4y+4z=16
One not way would be to define a 4x4 matrix Mat A to hold the coefficients of the linear system. Then define a 4x1 column vector Mat V to hold the constants on the right.
Define a third 4x4 matrix Mat B you may leave filled with 0.
On command line, in Run Mat screen enter (Mat A) ^(-1) and store it in the zero-filled matrix Mat B. this is the inverse of Mat A.
If the inverse of Mat A exists, and it does in this case, the solution of the system is obtained as the column vector, resulting from the multiplication of Mat B by column vector Mat V
You can even shorten the procedure by just calculating ((Mat A)^-1)X (Mat V) [EXE]
To summarize
  1. Create 4x4 Mat A and type in the coefficients of the linear system.
  2. Create a 4x1 column vector Mat V for the right-hand sides
  3. Obtain you solution vector as ((Mat A)^-1)X (Mat V) [EXE]
To get the Mat identifier on command line,
  • use catalog or
  • in RunMat screen, press [OPTN] followed by [F2:Mat], then [F1:Mat].
  • At this point the identifier is on command line, and you have to press [ALPHA] [X,Theta, T] to enter letter A.
  • You use a similar key sequence to enter Mat V
To calculate the inverse of the matrix just use the [SHIFT][)] key sequence which is (X^-1)
Multiplication operator is the regular [times] key.
Nov 16, 2010 | Casio FX-9750GPlus Calculator
How to get the inverse of a matrix an fx-991 ES calculator
The same way you would get the inverse of a number. Assuming you already have the matrix entered into memory, press SHIFT 4 to bring up the matrix menu, select the matrix whose inverse you want, then press the x^-1 key (just to the right and slightly below the big round cursor pad.
Nov 02, 2010 | Casio FX-115ES Scientific Calculator
How to calculate inverse of a 3x3 matrix in casio fx-991MS calculator?
Here is the solution for th FX-991ES.
The error may be due to the key you used to signifie inverse. It says in the manual that you should use the key x^-1 not the one used to input general powers.
Here is screen capture from the Appendix to the manual. The picture shows the sequence of keys to press to obtain the inverse of a 2x2 matrix. It is taken from page 41 of Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
The link is for FX991ES. Look there foe you manual.
Hope it helps
Sep 04, 2009 | Casio FX-115ES Scientific Calculator
I get a dimension error on my screen from my matrix
You cannot calculate the inverse of an arbitrary matrix. It must be a square matrix (nxn) with non zero determinant. Make sure dimensions m and n are equal. (2x2), (3x3)
To calculate its determinant [Shift][MATRIX] [7:det] [SHIFT][MATRIX][3:MatA] close the right parenthesis and [=].
If determinant is different from zero then you can calculate its inverse.
If matrix MatA has already been defined, you calculate its inverse as follows;
[SHIFT][MATRIX][3:MatA] [X^-1][=]. Use the X to -1 power , the one under [MODE].
For well-behaved matrices you calculate the inverse directly without worrying about the determinant.
Hope it helps.
Apr 16, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
562 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
