Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
DELL DIMENSION 5150 SOMETIME WILL NOT SWITCH ON
I HAVE POWER TO THE COMPUTER AND SOMETIMES IT WILL NOT START UP,IF I LEAVE IT TILL THE NEXT DAY, IT IMAYBE START, SO ITS A HIT OR MISS TO USE IT.
IF IT DOES START A BLACK SCREEN COMES UP TELLING ME THAT SOME FLOPPY DISC DRIVE NEEDS CONFIGUIRED AND THE DATE AND TIME NEED RESET, I INSERTED A NEW BATTERY THREE WEEKS AGO AND IT STILL WILL NOT ACCEPT THE NEW DATES AND TIME.
I JUST PRESS THE FI KEY TO GO AHEAD AND USE THE COMPUTER, BUT WHEN I SHUT DOWN ITS HOPING IT WILL RESTART WHEN I NEED IT AGAIN
    Sergeant:
  • 268 Answers
You need to get into the bios of your system and setup the date, time, and disable floppy boot. You may also want to clean any/all dust/dirt/hair from your system and make sure your fans are working. Sounds like your cmos battery failed (you changed that) and that your processor/motherboard is failing due to overheating
Company Site http://www.attechcomputers.co.cc
Posted on Jun 18, 2009
I have a Dell Dimension 5150 Desktop Computer. I leave it on for hours on end and it has become extremely noisy from time to time, even when I am not actually using it. Recently it has become very...
There are several reason for this issue.
1. Power switch on CPU(Tower) might get locked while pressing.
2. SMPS might be old one.
1. Need to check the Power switch with the help of Multimeter.
2. Need to change the SMPS and check whether it is working.
Nov 01, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a Dell Dimension 5150 with a P4 3.0GHz and 3GB DDR2 Ram. About a week ago it started shutting down...cold. Not a Windows shutdown. It is like someone unplugs the power. It will then start booting...
Syptoms u have identifies are most probably linked to registry errors on ur computer it is wise to run? a registry repair scan with reginout? registry cleaner....
Aug 30, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 Boot Problems!
You can probably try two things here.
1) Go to the BIOS and reset the defaults.
2) Clear NVRAM from your Dell computer. Here is how you do it.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=4C1BF720A3E78F92E040A68F5A2811BE&journalid=7788D9829DCAA7C8E040AE0AB6E12FA2&Query=bnZyYW0=&SystemID=DIMENSION+5150/E510&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Amber Flashing Power button on bootup
i would change the battery first of all. this is the reason for losing date and time
Jul 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer wont start up!
try to replace the IDE/SATA cable connection..good luck
Jun 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 does not start
Could be a number of things, First take the ram out and then put it back in and see if that helps. next I would unplug any devices not required to start the computer.
You need to be familiar with the inside of the computer to do this.
Most likely suspect however is the power supply.
Jun 19, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5000 Dimension starting issue
You need to change your power save options. Right click on the desktop, click properties, click tab screensaver click on power tab. set the desired power save functions. hope this helps
Feb 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
278 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
