Question about Microwave Ovens
G2 Whirlpool Microwave display turns off showing ''Mains Low''
I removed the display panel and checked voltages up to the Display PCB and Power PCB. While checking voltages on large wiring harness on the Power PCB the display kicked on and everything started working again. I reassembled, mounted and used the microwave for a week, and while I was cooking on the stove it happened again. Display showing ''Mains Low'' now for 4-5 days. My thought is that moisture from cooking on the stove is either causing bad connection on the Power PCB or I'm just totally lost.
MicrowaveSvc
  • 9098 Answers
SOURCE: 1994 Whirlpool Microwave Mod MH7115XBQ-2
You can find exploded view diagrams and order parts here: http://tinyurl.com/gv383 The most likely causes are: diagram 5, ref. 5 fuse diagram 7, ref. 2 thermistor diagram 2, ref. 5 control board If it's a problem with the control board, we repair them nationwide for $32.50. We also have important safety and disassembly information we recommend: http://tinyurl.com/yzjozk
Posted on Feb 04, 2007
SOURCE: Microwave Fan won't shut off, no display
Depending on which brand you have I would think that the Thermal switch on top of the magnetron or one of the door switches has probably given up the ghost. However, if the display does not come on you probably have a micro or Psu fault on the display panel. Not to be attempted if you are not familiar with microwaves or electronics. Please unplug before opening. Good Luck, JUS004
Posted on Jan 05, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Above the Cooktop Oven Microwave JVM1533 Turn table does not move
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
In this case, I would suspect the primary interlock door switch.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave Model MH3184XP will not power up after power failure
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again. Let us know if the hard reset doesn't fix it.
If not, then you may have a problem is on the control panel, which we repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
Posted on Feb 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
No lights on control panel, but works fine.
there two power supply one for the Magnetron and other low voltage for display drivers and relay.
also it will have 2 fuses one of 10 Amps other for some 500MA replace the second one .
Mar 25, 2014 | Whirlpool RMC275PD Microwave Oven
Whirlpool microwave g2 - Panel lights but no text visible
It is a logic problem or at least electrolytic capacitors that dim the display too far. The display could be repaired if it isn't a ic (logic) problem if it is then you need the whole display replaced
Nov 29, 2013 | Microwave Ovens
Kid put mom's curling iron in microwave. Turned it on and now nothing. No lights, nothing. Is there a fuse to check? Maybe it is too far gone? Thanks
there is very high voltage present even when disconnected from mains. unplug from mains & leave for 1 hour. remove cabinet. there is a fuse which controls everything usually located near the transformer or where the mains cable enters. check fuse and replace. it needs to be the correct fuse for the appliance
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations
Jan 11, 2011 | Whirlpool MH1150XMQ Microwave Oven
My Kitchenaid microwave goes in "No Mains" mode when I utilize the back burners what is causing this I have the distance from the cook top 18-20 inches
My Whirlpool elite does the same thing when i have the exhaust running while cooking hot stuff. The phrase No Mains with a cartoon character jumping up and down on the lcd display. Tech support claims its low voltage. But my voltage is fine. Moving the plug to a different circuit doesn't help. Unplugging it for an hour seems to be a temporary fix because the problem happens again.
Sep 19, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
No display on LCD panel on my whirlpool microwave
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Feb 11, 2009 | Westinghouse Microwave Ovens
Microwave does not heat
The high voltage circuit that supplies power to the magnetron may be separately fused inside. Unplug it, remove the back panel and look for a fuse clip. The high current fuses (20-30 amps) often have a white ceramic housing and are tubular. If you have a multimeter at home (you should, they are cheap) you can check the fuse after removing it from the holder.
The reason your other things are still working is that they have separate supplies; the one for the panel will supply only low voltages and not much current.
If you have a meter, check for a largish black plastic component often mounted on the floor of the case. This will be a diode or diode bridge and this can also fail.  A meter would let you check it if you have one.
Nov 28, 2008 | Whirlpool GH7145XF Microwave Oven
Whirlpool GH518XP
Sounds like it got hit with a power spike which could have burned out the low voltage components, (Control panel). How's your insurance coverage?
May 22, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool GH6177XPS G2 Microwave
Your generator may be putting out a square wave instead of a true sinusoidal (sine) wave.
There is usually a circuit in the microwave which monitors the AC line for timing purposes, and a square wave may not be interpreted correctly.
I would consult the manual or contact the manufacturer or installer.
Jan 08, 2008 | Whirlpool GH6177XPS Microwave Oven
Brother put a foil wraped burger in micro now everything is dead
Hi, You may want to try to check/troubleshoot the PCB underneath the display/control panel. The mains do supply two circuitries: the heavy load and the electronics. In some units, they have a standard transformer while in others an SMPS that supplies the +5 (and sometimes +12 or higher) voltage. This powers the electronics which includes a microcontroller, timer, relay drivers and display panel. Trace the transformer/SMPS and look for any fusible link, secondary fuse or surface mounted fuse. More often than not, there are also standard components along the way like bride diode, diode, filter capacitor and regulator IC. Check for VDC input and output of power components. Hope this gives you an idea, Pls post again how things turn up or if you need further information. Good luck and kind regards.
Aug 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
482 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
