Question about Frigidaire FAC127S1A Air Conditioner
What is the size of this unit - Frigidaire FAC127S1A Air Conditioner
Panasonic cu2473kr hello I am after the pipe sizes suitable for a five meter run from outdoor to indoor unit or a service manual would be great thanks
The proper size is dictated by the connection points on the inside unit. Measure the two refrigerant lines and run that sizes to your outside unit. This piping needs no adjustment for 5 meters (a little less than 20 feet).
Dec 18, 2014 | Heating & Cooling
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
Please advise wire and breaker size for this unit. Thanks Doug
On any piece of equipment look for the model number tag and check for something that looks like M.C.A. and/or M.O.C.P. (with or without the .'s after the letters) The MCA is minimum circuit amps which indicates the minimum wire size and therefore minimum breaker size as well. The MOCP is maximum over current device. This is the Maximum fuse or breaker size recommended for the unit. However, both numbers are more importantly linked to the wire size feeding the unit. You must be certain that the wire size is large enough to provide proper voltage without overheating and not put too large a fuse or breaker for the wire size. A good electrician or an electrical chart for wire sizing is very important.
Dec 11, 2010 | Heating & Cooling
I need to know the proper piston size for this unit when it came with a 63 on one peice and a 68 on another I used the 63 and the unit doesn't seem to be working properly please advise
use the size that came with the outside condenser. if the outdoor unit is more than 6,000 btu's than the indoor unit, it will not cool properly. you can always mate a outdoor unit to a indoor coil that in 12,000 btu's or less in size.
Oct 10, 2010 | Goodman CKL42AR42 Air Conditioner
What is the voltage polarity ac or dc of the power adapter for SP-613 speakers?
this is actually the product description for your speaker
Product Description
Front
Speaker Unit: 1inch +6.5inch *2+8inch
Power: 10-100W
Sensitivity: 88 dB
Impedance: 4 ohm
Frequency Response: 45-20K Hz
Production Size: (H*W*D) 1087*210*336mm
Package Size: (H*W*D) 1162*500*400mm
CENTRE
Speaker Unit: 1inch +4inch *2
Power: 10-60W
Sensitivity: 86 dB
Impedance: 8 ohm
Frequency Response: 75-20K Hz
Production Size: (H*W*D) 160*500*179mm
SURROUND
Power: 10-60W
Sensitivity: 85dB
Impedance: 8 ohm
Production Size: (H*W*D) 225*160*158mm
Package Size: (H*W*D) 550*273*415mm /3PCS
ACTIVE SUBWOOFER
Speaker Unit: 10inch
Impedance: 8 ohm
Crossover Point Control
Handling Power: 120W
Production Size: (H*W*D) 405*328*350mm
Package Size: (H*W*D) 465*330*465mm
Jun 24, 2010 | Juster SP-615 Computer Speakers
Would like to replace need to know size of unit and age.
this unit is a 3 1/2 unit...the 42 the model number...possible its a 89 or 97 model...this is a 42,000 btus unit...hope this helps...michael 843-384-8474..
Mar 27, 2010 | Heating & Cooling
Canon IR 2870 A3 printout tail crumpled
Hello sir; When you print A-3 size paper did you set up on computer for a-3 size paper, most case A-3 size use in europe, usa use letter size. I hope that's the problem,
Jan 29, 2010 | Canon Office Equipment & Supplies
How to tell the size of my ac unit?\
thats a 5 ton ac unit
10AJA6001AH
basically 1 ton = 12,000 BTU
so 24 is 2
30 is 2 and a half
etc
Jun 21, 2009 | Weather King Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Window unit
The adapters that come with the unit are sized according to the size of the unit so that when they are fully retracted they do not ove lap the unit. There are different size units depending on how many btu's are required for cooling. If the window is larger than the wing span of the unit you will have to prefab the difference.
Sep 27, 2008 | Frigidaire FAA065M7A Air Conditioner
Frigidaire FAC127S1A Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
