Question about Ruud Central System Air Conditioner
Have Rheem 5 ton heat pump with stacked coils poor cool.
Have Rheem 5 ton heat pump with stacked coils.
Only 3 rows on bottom and 2 rows top coil get
cold. unit will not cool house on hot day 83 degrees lnside, 92 outside. Freon 62 psi, filters clean, coils not to dirty very expensive to clean stacked coils. Compressor
still under warranty nothing else.
    Sergeant:
  • 340 Answers
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
Posted on Jun 18, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
2003 ford windstar spark plug wires diagram
I\'m assuming you have the 3.8 engine,although i believe the firing order is the same on all there v6 sideways mounted front wheel drive Windstars. That firing order is 1-4-2-5-3-6, with 1-2-3 going from left to right on the back side of the engine and 4-5-6 left to right on the front side of the engine.Looking straight down at the coil from the front of the car,you\'ll see 2 rows of coil terminals.The row on the right side is 1-2-3 going from top to bottom,row on left side is 6-5-4 going from top to bottom. Hook the number 1 coil terminal to the number 1 spark plug ,being careful to use the spark plug wire that is closest in length to the length you need. If your just replacing wires,yuo shouldn\'t have to much trouble. If your nreplacing the spark plugs you will find the ones in the rear,especially the number 2 [the middle one} are pretty difficult without removing the cowling. A total pain brought to you by the designers at Ford!
Jun 04, 2014 | 1998 Ford Windstar
Why is my air conditioner freezing?
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil)
May 25, 2014 | Rheem 13PJL36A01/RHSLHM3617JA 3 Ton 13...
Aircondition builds ice on coil
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil) Good luck.
May 19, 2014 | Rheem Complete Split System Gas Furnace 5...
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
Firing order in coils, cavalier, chevrolet, 99
STANDING IN FRONT OF CAR FROM LEFT TO RIGHT CYLINDERS ARE 1 2 3 4 NOW LOOKING AT COILS STANDING FRONT CAR THIS IS COIL SPARK PLUGS WIRES LOCATION WRITE THESE NUMBERS DOWN IN A ROW LIKE NUMBER 2 ON TOP 4 BOTTOM 2 3 1 4. THESE NUMBER IN A ROW IS WHERE YOURS SPARKS LOCATION FROM COILS TO CYLINDER SPARK PLUGS.
Mar 15, 2011 | Chevrolet Cavalier Cars & Trucks
I have a Rheem heat pump/air handler; it draws 2.9amps with only the fan running, 13amps when the heat pump is running and 38amps with the heat strips on. My question is why the unit draws that many amps...
Sounds like it must be about a 2.5- 3 ton system. The 13amps has to be the compressor draw -normal. and 38 on the strips- normal. 2.9 fan -normal.
You may want to check your wiring to see where the outside unit gets its power. Theres nothing inside that can draw 13 amps. That almost has to be the compressor power wire.
Jan 27, 2011 | Heating & Cooling
My 4 ton goodman heat pump goes into defrost and than after the cycle return in cooling stage at least the indoor coil starts freezing is the expansion valve working corectly
The reason for indoor coil freezing due to coil dust blocked-(Clean coil). 2. Less rpm of indoor f.motor. (Replace capacitor). 3. Short of gas. (Find leak and repair and then recharge gas.)
Jan 04, 2011 | Heating & Cooling
Just replaced inside fan motor on 5 ton Rheem heat pump. Fan will not spin freely. What to do?
1) remove power from the unit
2) remove panels enough to see where the squirrel cage fan is binding
3) these units are normally adjustable by loosening the bracket which holds the fan motor and simply moving it one way or another just a bit. (which is why understanding which end of the fan is binding is a GREAT second step, right after step 1, remove power from the unit, that includes shutting the emergency heat coils breakers OFF.
Don't worry, you're close to the solution!
Nov 25, 2009 | Ruud UBHC Air Conditioner
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Sep 19, 2009 | Heating & Cooling
Ruud Central System Air Conditioner Logo
304 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
