Question about Delphi Roady XT XM Radio Receiver
Antenna i jus bought xm road ready and it keeps saying antenna i have it mounted right could it be an internal problem?
I just pushed the radio into the boombox real harder and the message isn't there. We'll see how it goes. I think it was that simple for me though. Thank you God.
Posted on Apr 01, 2009
I had a problem with mine. I thought it was the antenna. it's actually the car kit dock. I have to wedge a fold chunk of paper at the back to keep the pins in contact. haven't seen 'antenna' msg since.
Posted on Jan 06, 2008
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
I bought sirius radio for my husband who drives a truck. He is having trouble keeping a signal. The truck is a large four-car hauler and we wondered if placement of the antennae was the problem. Even...
They make a special antenna that mounts on the the mirror mount for the big rigs. You need a big antenna, as the regular one isn't going to work very well on a big rig. Many full service truck stop stores have the big rig antennas. Try that first. You might have better luck with XM than Sirius too,
Dec 28, 2009 | Sirius Satellite Radio Receiver
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
XM radio ''NOT READY'' message
I have had this problem at least a half-dozen times, and the simplest solution is to pull the 2 fuses labeled 'audio 1' and 'audio 2.' It resets the radio, but it will work for a while after that (until I have to do it again). Had the xm unit replaced 3 times, new antenna installed, replaced the antenna connection wire - it always dies within a month.
Sep 24, 2009 | 2008 Hyundai Veracruz
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
We had an xm radio installed in our 2010 prius after we bought it. It was ''satellite ready'' but needed the radio. We signed up for xm radio and tried to get the signal. The radio was tuned to channel...
go to who installed you sat radio have them pull the antenna and receck the the receiver number it sounds like you have the wrong reciever number even one digit off and it will never conect even tho you have preview and sat radio paired with an antenna will recieve preview
Jul 10, 2009 | 2009 Toyota Prius
"not ready" message on XM radio
Remove the Audio Fuse and then put it back in and the problem is solved. So frustrating that I had to find this solution on another site as both the dealer and XM had no idea how to fix it. Dealer tried to tell me it was a bad radio and I'd have to get a replacement from Hyundai.
Jul 02, 2009 | XM Radio Dual XMP7000 Auto In-Dash CD...
It keeps saying antenna
The Tuner is bad. It's a very very very common problem among Sirius and XM users. It's a cold solder joint at the antenna input of the receiver. If it's out of warranty, replace it. Check ebay or Google it and you can find a replacement cheap. Sorry for the bad news, but that's the answer. Hope this helps
Jun 22, 2009 | Delphi Roady XT XM Radio Receiver
Hyundai sonata xm radio now saying antenna when turned on
antennas are susceptible to damage in carwashes.
Apr 17, 2009 | XM Radio (XMP6000)
Xm stopped working display says "antenna"
Broken antenna cable. Likely you have a kink or worn thru point on the wire somewhere.
Aug 09, 2008 | XM Radio (XMP6000)
Delphi Roady XT XM Radio Receiver Logo
297 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
