Question about Fuji FinePix Cameras
S4800 wont turn on
S4800 3 sets of new batteries tried. sd card removed camera is 2 months old, undamaged and has been working fine until today battery contacts are clean and touching
SOURCE: samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Posted on Jun 16, 2008
  • 51 Answers
SOURCE: Why do I get Error 99 in my Canon EOS 350 D?
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jan 30, 2009
DUMPLINS559
SOURCE: i733 Polaroid camera will not turn on
well I HAD THE SAME PROBLEM ALL I GOT WAS A BLACK SCREEN & 3 BEEPS,SO GOT A LETTER OPENER AND STUCK IT IN THE SPACE BETWEEN THE ZOOM LENS A FEW TIME VERY CAREFUL PUSHING DOWN THE POWER BUTTON AT THE SAME TIME AFTER A FEW TIMES THE LENS BECAME UNSTUCK..JUST JIGGLE IT A ROUND A LITTLE BACK AND FORTH WITH A LITTLE FORCE.I HOPE YOUR CAMERA WILL START TO WORK AGAIN LIKE MINE DID.
Posted on Feb 05, 2009
  • 4090 Answers
SOURCE: playback and menu buttons freeze camera
This is a circuit board problem, return the camera for warranty repair replacement.
Please rate my help++++Thanks for usinf FIXYA
Posted on Mar 24, 2010
lock123
  • 6831 Answers
SOURCE: nikon d80 will not take pics has err flashing in
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
My primos 46 camera says SD card full when it has never been used
If you have not used the camera in a long time try to reset it. If it was installed on your computer try to reinstall it. Sometimes that will work . I hope this helped a little.
Aug 18, 2012 | Primos Truth Cam 46
I got my camera 3 weeks ago. Now Im on vacation in Thailand and used the camera snorkeling. Yesterday the camera "froze" so the only way to get it going again was to remove the battery. Today...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 04, 2011 | Pentax Optio W90 Digital Camera
My camera switches off immediately after swithching on, it just shows a low battery sign and goes off. On the contrary if I select the discharging option from the camera settings menu the same batteries...
These cameras use both SD and XD cards. The SD cards are the cause of the draining. Switch to an XD card or remove your SD card while not in use and your batteries will not drain. :)
Jan 01, 2011 | Fuji FinePix S1000FD Digital Camera
SD card error in non-new Z20fd
1. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. 2. If the problem persists, go into the menu and find "reset" and follow the on-screen instructions.
Feb 03, 2010 | Fuji Finepix Z20fd Digital Camera
Z612 will not format an SD card... 1GB??? Also battery life is very short... have used Kodak battery and a LENMAR DLK8000. And more... lens does not extend when camera turned on! Best Buy has had the...
Your camera has been designed to work with SD cards up to 1GB but in my experience there are often compatibility issues with different brands of SD cards especially when they're right on the limit of what the camera can handle.
You've said what batteries you've tried, but they will not affect how your camera behaves when trying to format an SD card.
I'd recommend first trying to reformat the card in an external reader (you may have to try reformatting in FAT 16 and then in FAT32 to see if it makes a difference: alternatively contact Kodak to ask which one to use as they don't say which in the published technical specs for your model). If this doesn't work then my next suggestion is to try a previously unused (i.e new) example of another brand of SD card; as they're so cheap you may want to do that anyway. You're safest to assume that a Kodak branded card will work, and SanDisk are also very widely compatible on "problem" devices. If either of these cards do not work then you'll find that the manufacturers are both very supportive in trying to resolve your issue, although ultimately you may discover that you actually have a faulty camera.
Nov 04, 2009 | Kodak EasyShare Z612 Digital Camera
Kodak Easy Share M763 Won't turn on!!
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Sep 02, 2008 | Kodak EasyShare C533 Digital Camera
DXG 506V Will not turn on
I had the same problem ...I bought a new 2 GB SD card put it in the camera and it worked fine.
It may have had something to do with formatting ..I tried to format the other card wiyh my computer when the video camera would stay on.
I tried to reset the camera that didn't work either.
The new SD Card did work.
-Steve
Jun 04, 2008 | DXG Technology DXG-506V DV Digital...
Memory card error
Try a smaller memory card size . I was trying to install a 4gb card and the guy at Kmart told me to try a 1gb card and that fixed the locked card error . No where in the instruction book did it address this problem.
Sep 24, 2007 | Canon PowerShot A530 Digital Camera
Insert memory card, LCD turns lank
Hello Rach326, try with a new SD card. If it does not help contact the nearest authorized dealer/service. Best regards, Arpad
Jan 12, 2007 | SeaLife Reefmaster DC310 Digital Camera
Cameras Logo
22 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
