Question about Bose acoustimass 5 series II Speaker
Input cable wirring diagram bose accoustimass 25 series2
2 Suggested Answers
  • 11 Answers
SOURCE: Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
Posted on Sep 17, 2008
How to connect Mackie Mixer 1402vlz4 to Bose Accoustimass 5 speaker
you need a power amplifier between the mixer and the speakers to actually drive the speakers. You would have to choose which amp to use (the manual, found here: http://www.bose.ca/controller?url=/shop_online/speakers/stereo_speakers/acoustimass_5/index.jsp#manuals suggests between 10-200 WRMS for power), and thus would have to determine the cabling options depending on the amp you choose, but...go from either the MAIN or CONTROL ROOM outputs of the Mackie mixer into the inputs of the power amp. Then go from the outputs of the power amp to the inputs on the Acoustimass bass module, which also runs the Acoustimass satellite speakers.
Apr 17, 2014 | Music
How do you open the cover to bose accoustimass
Bose Acoustimass is a bandpass cabinet. Needs to be sealed. I recommend to send it to a service center.
Nov 21, 2013 | Bose Lifestyle 12 System
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Hoe to connect Bose Lifestyle 25 Home Theater System speakers to onkyo SRX-508
Do you mean TX-SR508? The following should work even if that is not the exact model.
The LS25 supports ONLY analog stereo audio input and the speakers themselves are NOT desigend to be driven by anything BUT the LS25 electronics.
If you still want to use the LS25 as speakers just run an RCA cable pair from VCR / DVR Out on the Onkyo to the AUX IN on the LS25 Music Center.
http://www.retrevo.com/support/Onkyo-TX-SR508-Receivers-manual/id/23653ag910/t/2/
http://www.retrevo.com/support/Bose-Lifestyle-25-Series-I-Home-Theater-Systems-manual/id/525ag019/t/2/
Dec 28, 2010 | Bose Lifestyle 25 System
How can I connect my bose lifestyle 12 series2 system to a yamaha receiver model rx-v3000
you will need to go to your local electrical store which will provide a box which you plug your speakers cable into and it will allow you to plug the box into the receiver using the Digital Left and right Audio cables.
Jul 18, 2010 | Bose Lifestyle 12 System
Is there a current model receiver that I can puchase to drive my existing subwoofer and 5 speaker set? My Series 5 died.
How to connect Bose Acoustimass 25 series II subwoofer to Denon Receiver using factory provided 13pin cable
Oct 25, 2009 | Bose Lifestyle 25 System
Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Apr 10, 2009 | Bose Acoustimass 16 System
Yamaha RX-V861 Low frequency "flutter" after turning on
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
Apr 03, 2008 | Yamaha RX-V661 Receiver
Bose acoustimass 5 series II Speaker Logo
37 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
