Question about KONFTEL Lands Phones
Making beep sound
Randomly making being sound with no notification
Chime comes on quite a few times a day with no message. any ideas
Galaxy S5: Notification sounds when I do not actually have a ...
forums.androidcentral.com > ... > Samsung Galaxy S5
Apr 27, 2014 - 18 posts - ‎14 authors Multiple times throughout the day, I hear a notification sound (like I have a ... sound(like I have a text message) but there is no notification of any sort ... Quote Originally Posted by Tampaguy75 View Post. I am having an issue ... Note 3 Random Notification Sounds?
Oct 14, 2013
recurring notification sounds and vibrate
Apr 18, 2011
More results from forums.androidcentral.com
Nov 04, 2015 | Cars & Trucks
Phone makes a loud irritating sound when the phone loses a wifi signal
you have to go sound setting and off your wifi sound by manually
May 20, 2017 | Blu Cell Phones
Random short beep
Does it do it with the sound muted? Is it a BIOS type beep? OR, Open your Sounds, Sound Scheme, try to ID the beep by going through the Sounds Scheme, testing each one.
Jan 24, 2013 | Toshiba Satellite C655-S5125
My 99 vw beetle keeps making beeping sounds at random and constantly for no apperent reason and the abs light also appears or stays on for extended amounts of time (not related to the random beeping) any...
check make sure alternator charging battery if alternator fails volts out put 11.0 volts that will set off abs light, if alternator okay have vechicle abs brake system scanned at the volkswagon dealership.if abs light flashing while in motion could have faulty wheel speed sensor.
Sep 18, 2012 | Cars & Trucks
How do i set my samsung galaxy gio to beep when i miss a text
Bring up your settings menu, and go to sound settings... You'l see the notification ringtone and you can choose from that menu whatever sound you'd like for your notifications
Nov 25, 2011 | Samsung Galaxy Gio s5660
I have the HTC wildfire and the message alert has turned itself off so that it doesn't beep, it only vibrates. I've tried going to main menu, messages, notifications and it's got tick on receive...
I have the HTC wildfire and the message alert has turned itself off so that it doesn't beep, it only vibrates. I've tried going to main menu, messages, notifications and it's got tick on receive notifictaion and notifiction sound but there is no sound. Please help.
Aug 23, 2010 | HTC Wildfire Cell Phone
Can't work out how to turn on sound for reminders ONLY
Hi. Just tap Settings from Start Menu, then tap Sounds&Notifications, in the second tab, you can change all the settings for your device's sounds and notifications. Hope this helps.
May 13, 2009 | HP iPAQ RX3715 Pocket PC
Need help
Make sure that in the set-up, you do not have the feature turned on that makes a beep for each minute in use. This is a common cause.
Check the user guide for details.
Jerry G.
Jun 03, 2008 | Samsung SCH-u340 Cellular Phone
Monitor is putting out a really annoying high tone
Sounds like you have a capacitor going bad. All monitors make a noise, whether the human ear can usually hear it or not. If it has gotten rather loud, I'm afraid your monitor is on its last leg. White is a hard color for a monitor, because the electron gun inside has to fire on all pixels, and of course black is easiest because it is just blank. Some people I've talked to have had temporary relief or prolonged the life of their monitor by keeping it on lower resolution in order to make its job a bit easier. Besides that, there isn't too much you can do.
Sep 18, 2006 | Compaq fs740 17" CRT Monitor
Lands Phones Logo
Top KONFTEL Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a KONFTEL Lands Phone Expert? Answer questions, earn points and help others
