Question about Kitchen Ranges
Viking VGSC3064bss knob keeps turning...how do i fix it
It doesn't stop on the off position. it just keeps spinning.
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
machinetech7
  • 1344 Answers
SOURCE: Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Posted on Apr 29, 2012
ercupa190
  • 12223 Answers
SOURCE: GE Gas stove knob has no stop and keeps spinning
see this cause and fix it:God bless you
Power Supply
Make sure breaker is not tripped. Check power at outlet with a voltmeter. If any part of the oven works means you have some power but you may not have full power check the cord connections.
Main Control
Check to see if you have power going to the control. To do this you will need to remove the control. This procedure varies from model to model. Check the 2 leads feeding power into the control refer to the tech sheet or service manual. You should have 110 volts going in. If you do and the control does not respond check the keypad if equipped or replace the control.
Keypad
Some controls have a separate keypad. This is an electronic pad that is sometimes glued to the control. To check for stuck keys press each button one at a time followed by the cancel key, you should feel each one retract if any do not feel right I would lean towards replacing the keypad. You might also get an audible beep after each one, if you do make sure all respond the same. Look at the keypad carefully for any burn marks.
Posted on Jul 20, 2012
How do I fix an error code?
The problem it's reporting is a door latch fault. It may be a faulty latch, or you MAY just be able to clear it if it was a hiccup. Try the following six steps to clear the code, then see what hppens:
·Turn the appliance knob to the off or reset position, 12 o'clock.
·Turn the knob to the 6 o'clock position.
·Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position (One click clockwise).
Continue holding the spin button for about 5 seconds
·Release the spin button
·Immediately turn the knob to off
When your turn it back on it should have cleared the error code
Dec 24, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
How do I fix an error code on a Bosch clothes washer/
Dec 24, 2015 | Bosch Washing Machines
Hi, How Can I Reset error in my wash machine Bosch
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
I have a 202 GSX1300R and it won't idle.
Is the engine running at high idle or are you having to hold the throttle open to keep it running? If it stays at high idle on it's own be sure that when you push the choke back to the "off" position, check your linkages and be sure that the choke cam is returning to the low idle position, also be certain that your throttle grip operates without obstruction when returning to idle position. If you are having to hold the throttle open to keep the engine running you are probably going to find carburetor issues. Hope this help to get you looking in the right direction.
Dec 14, 2011 | 2002 Suzuki GSX 1300 R Hayabusa
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
F 21 keeps flashing and the machine is stalled and wont spin even after cleaning filter?
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
Nov 27, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My front right bruner on the viking range wont
pull knob straight.off use a pliers to turn shaft to off position.shop an appliance parts store for a new knob.
Sep 25, 2009 | Kitchen Ranges
Spin cycle doesn't cut in
turn program knob to spin and hit start then hit cancel within 5 seconds hold down options and start/pause button this will put you in the self daignostic test
the loading door can be opened.When the door is
opened, the drum light should turn on.
position. The washer will fill and tumble. Once
tumbling has started, the Boost Heater (if so
equipped) will turn on.
position. The drain pump & door lock solenoid will
then on the last turn it will give you the other error codes it has that code is giving usually is caused by a different code to clear the codes
• Turn the program knob clockwise 7 clicks from the
Start Position. The control will signal the last error
code.
• Press and hold the Options and Start/Pause
buttons for 3 seconds. The code will be cleared. you really need to clear that code first to do the test but it can be done in the daignostic test skip the rest first go straight to the 7 clicks and clear the code but dont open the door during the test otherwise it will give that code after you get it cleared go to the spin spot on the knob and keep turning clock wise to go through the test but give it at least 3 seconds for each test then it should display a different code and what ever it is email me and i can help you out at that point nick_bradford2003@yahoo.com i have alot of experence with appliances
Jun 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Jun 19, 2008 | Viking VGSC306-4B Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
