Question about Dishwashers
Dishwasher wash light flashes
The dishwasher won't start when turned on. The was light flashes and the machine beeps, while the motor can be heard running. It would appear that water is not getting through
  • Sam Apr 16, 2014
    Hi Peter Curtis, I want to help you with your problem, but I need more information from you. Can you please add details of the dishwasher in the comments box Model number and make?
  • Peter Curtis
    Peter Curtis Apr 16, 2014
    The dishwasher is a Siemens Everdure DWF125WR
  • Dishwashers Master
  • 3,247 Answers
It might be helpful if you are able to identify the country where you are located. I am unable to locate any specific references to this dishwasher model on the Siemens website.
In the meantime, my observation is that the flood switch is coming on. This means the water leakage detection device that is hooked up to the dishwasher is triggering and causing the water inlet valve to shut and run the drain motor in the belief the dishwasher has flooded. These dishwashers of European origin usually have the leak detector circuits hooked to the inlet water hose. Even if the hose is crimped or crushed can cause such behaviour.
Posted on Apr 19, 2014
  • Sam Apr 19, 2014
  • 848 Answers
SOURCE: Our Whirlpool KUDP01ILBS2 dishwasher isn't
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Posted on Feb 10, 2009
SOURCE: FDW60 dishwasher
I've just (as of 10 minutes ago) had the same problem. I followed the advice given elsewhere in this forum and removed the bottom cover - water running out so needed a big towel to mop it up. I stood the machine upright and restarted it - no problem! it started straight away.
The question now is where is the water coming from? It seems there is obviously a leak somewhere and water is gathering in the undertray setting off the microswitch.
Posted on Nov 05, 2007
SOURCE: FDB1050REC2
Follow up to my Jun 02, 2008 post. We had a service tech come out today, and it turned out that the door switch was bad. The neutral side had continuity with the door shut, but the hot side was sporadic. A new switch has been ordered.
According to the Frigidaire tech sheet attached to the door, which is located beneath the control panel and behind the door skin, the problem could potentially be a bad control panel also.
Hope this helps someone in the future!
Posted on Jun 03, 2008
  • 3 Answers
SOURCE: Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Posted on May 15, 2009
  • 52 Answers
SOURCE: start light flashes - lot of water in machine - she no work!
check to make sure the drain hose and filter is clear
Posted on Jul 26, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Control lock light is on and dishwasher doesn't start
There is a Control Lock which locks all the control buttons, so the dishwasher cannot be started. It is enabled by pressing and holding the lock button for about 3 seconds. To disable, press and hold the lock button until the light goes out. A single beep will be heard when the feature is turned on.
There is also a Keylock feature which locks the drawer shut and disables all the controls so the dishwasher cannot be opened or started. It is enabled by pressing and holding the lock button for about 5 seconds. To disable, press and hold the lock button until the lock light goes out. Two beeps will be heard when the feature is turned on.
Both these functions are safety features that enable the consumer to lock the dishwasher controls to prevent children from inadvertently starting the appliance.
These instructions are on page 12 of your owner's manual. If you no longer have a manual, you can obtain a FREE copy at managemylife.com. Just go to the site and type in your number under the "Manuals" link. These manuals are available in .pdf (Adobe) format that you can download or print for FREE.
(posted by Jeff Rockwell)
http://www.whirlpool.com/owners-center/owners-center-homepage.content.html
Mar 11, 2013 | Dishwashers
The light keeps flashing an going beep beep dishwasher isnt doing it's job not washing
On my dishwasher if I hold down the start button for a few seconds it resets the cycle could you do that with yours as mine is a different make?
Feb 02, 2013 | Dishwashers
Hotpoint BC1450 Light 2 normal flashes
Flashing lights, pump running even when turned off. Had to switch off at the socket. The vibration from the machine had managed to give a quarter turn to the appliance gate valve, the type with the little blue handle. I could see the indentation in the rear rubber panel on the back of the dishwasher. Unscrewed the little blue handle, pushed the machine back in and started working as normal. :)
Oct 07, 2012 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Intake/Drain light is flashing and dishwasher won't do anyhting. I gve cleaned the filetr and still nothing
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Jun 08, 2011 | Miele 24 in. G638 Plus Free-standing...
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Mar 04, 2009 | Westinghouse Dishwashers
Fails to start Midea dishwasher WQP12-9240AS
Thankyou Loopyloolisa! you just helped me fix my unresponsive midea dishwasher! Great help
Jan 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
