Question about Dewalt D24000S HeavyDuty 10inch Wet Tile Saw with Stand
Blade turns until you push against tile
It was working fine and all of a sudden, when it touches tile the blade quits turning. Pull it back and turns again.
    Sergeant:
  • 272 Answers
You may have some burnt windings in your motor. If so, you'll have to replace the motor.
Posted on Apr 18, 2014
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
The blade won't stay on even though I have it on properly it comes right off when I turn it on
I have no experience of portable bandsaws but do have some experience of workshop bandsaws.
One wheel is generally movable in order to "steer" the blade and careful adjustment is needed with the blade guides retracted until the blade runs full on the wheels. The blade guides are then brought back to prevent the pressure against the work from pushing the blade off the wheels.
Oct 04, 2015 | Milwaukee tools 6242-6 Compact PortaBand...
My mk470 turns on and is really making a crazy sound but the blade wont turn
The motor on your tile saw is like a grinder, in the head is a set of gears, one on the armature and another at 90-degrees on the arbor. If the teeth on either or both gears are stripped off it will act and sound like you describe. When you move the motor or blade you are putting enough pressure on the gears that they touch enough to move the blade but it will never cut a tile. I have worked on these tile saws and have not been able to find parts for the motor to repair it. The entire motor is available on sites like www.ereplacementparts.com, part number 156428-R, but it's over $200 plus shipping.
Apr 06, 2012 | Mk Diamond Mk -470 7inch Tile Saw
Clippers have suddenly stopped cutting and seem to pull at the hair
Generally removing the two screws.. on the blade foot (don't do this over the sink unless the drain is closed!).. and taking the blade apart.. cleaning the trimmers with a small brush.. apply grease in the blade groove.. reassemble
Usually it's best to put those two screws back just get them in lose.. not quite snug..set the blade upside down on a flat surface..so it pushes the blade back away from the cutting end..level..then tighten those screws while you are pushing or holding down on the clippers cutting edge against the flat surface/table. ... oil the blade with the proper oil or a light mineral oil.
This usually will get them back to cutting properly..the blade should be oiled prior to each use...about two to three drops right along the visible part..or a light spray also hair should be clean.. dirty hair does not cut well at all..and the clippers will tug and pull rather than cut cleanly.
Lastly..if they see a lot of use. might be blade replacement time..
Best of luck!
Apr 13, 2011 | Oster 76076-010 Hair Trimmer
Target wetsaw starts and runs fine. Half way through the tile the blade binds and the motor bogs down which trips the breaker. It does it every cut now. Never had an issue before. Tightened the belt, still...
First thing I would check is that the table is square to the blade. If the back edge of the table that pushes the tile through the blade isn't perpendicular to the blade the cut will start fine but as you go through the tile the table will be pushing the tile into the side of the blade and cause a huge amount of friction, making the motor work harder and eventually pop the circuit breaker.
Jan 21, 2011 | Husqvarna Saws
Can you take it apart?
Quite difficult. The base that drops down to house the flex is fixed into the main body with two barbed flaps on the central plastic shaft. To remove, pull out the base as far as it will go (about 15-20mm) locate the plastic flap, insert a flat screwdriver and push against the top of the flap where it enters the base of the main body. Push gently until the barb unlocks and the other side should pop out. If not use another screwdriver to push and release the second flap. Why do you need to open it? the blade loose?
Feb 04, 2010 | Bodum 's C-MILL electric blade coffee...
The whole blade set has come off and we have no manual to put back together
There is a small gun-metal colored bar at the very rear, just below the back of the blade when it is only the clipper. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
If you have taken the blade off and the tongue has for some reason flipped back against the head, slide a screwdriver blade behind it and flip it back out so you can slide the blade back on it.
Good luck
Sep 22, 2009 | Oster Golden A5 2-Speed Universal Motor...
Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Tile Saw Troubleshooting
options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Aug 27, 2008 | Mk Diamond 5.3 amp Tile Saw
Dewalt D24000S HeavyDuty 10inch Wet Tile Saw with Stand Logo
118 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
