Question about Husqvarna Viking 1
Viking sewing machine
How to thread a Viking sewing machine
Re: Viking sewing machine
Go here! FREE!
Posted on Feb 09, 2008
    Problem Solver:
  • 12 Answers
There should be a diagram on the machine telling how to thread the machine. If not you can order a new manuel for your model Online.
Posted on Jan 19, 2008
I have lost my manual, it is somewhere in my house. I do not want to buy a new one. I just need a diagram of how to thread my machine.
Posted on Jan 27, 2008
5 Suggested Answers
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine: shows that they have this downloadable in Adobe PDF format here:
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
  • 46 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
bbragg77 is mostly correct. It is not the camstack. Although they will crack, but that is all together another problem. It is the stitch length/reverse mech. You can manually work it back and forth to free it and I like to use break cleaner to get it free then re lubricate. A good service shop can put you back in business. And yes Viking does not support 6000 series machines any longer.
Posted on Jul 25, 2009
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 152 Answers
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Posted on Oct 14, 2009
  • 165 Answers
SOURCE: My Viking Rose sewing machine starts and stops and
The Rose has a sensor on the presser bar assembly that is giving you the grief. The machine thinkss the presser foot is in the raised position.There is a small metal flat spring that has gone bad and causing the error. Find an autorized service center to repair the problem.
Posted on Apr 15, 2010
Testimonial: "Thank you. At least when I take it in they can't fool me into thinking it is something else! "
0 characters
3 Points
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
I need to wind thread the bobbin for a husqvarna viking 500 computer sewing machine
Download your manual here:
Feb 02, 2016 | Husqvarna Sewing Machines
How do I thread an Elgin Model s1112 sewing machine?
Manual for elgin sewing machine model S1112 - Fixya
Jul 21, 2012 - I need a manual for an elgin model S1112 sewing machine. Posted by .... the thread stuck when m starting to saw on Elna 120. Jan 22, 2016 ...
Viking engineered 1958 "Elgin 2468" - Introduction - YouTube
? 14:20
Oct 15, 2012 - Uploaded by CowCountryVintageSewing MachinesAndRestoration
Sewing machine won't pick up bobbin thread ' hook timing fix - Duration: 6:08. ejc1210 387,297 views. 6:08 ...
? 2:32
NICE ELGIN SEWING MACHINE 1.5AMP STRAIGHT STITCH ... Viking engineered 1958 "Elgin 2468" - Two ...
Elgin sewing machine model s1112 manual - Google Docs Google Docs, Sheets, and SlidesSewing machine manual elgin sewing machine model s 1112 ebay. Sewing ...Sewing machine manuals and free threading diagrams from sewusa. Sewing ...
Thread: Elgin Sewing Machine - Quilting Board
Jan 24, 2016 | Sewing Machines
Need to know how to take the cover off of a viking 400 sewing machine?
Screws are either T10 or T20. There are some on the back and some on the bottom. However, would recommend taking it to a Viking Service Tech for repair. Occasionally you can use tweezers and pull thread out if it is not tightly embedded in the sewing head. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website -
Aug 18, 2014 | Husqvarna Viking 1
Why is my bobbin thread jamming on viking juliet sewing machine
Be sure to clean out any stray fibers or threads in the bobbin area. Make sure the bobbin is smooth and doesn't have nicks or scratches.
Aug 02, 2014 | Husqvarna Sewing Machines
Viking 870 sewing machine thread tension discs loose
The tension disc are suppose to be loose, that is not a problem, but if you don't seat the thread between them the machine won't sew right
Aug 13, 2010 | Husqvarna Viking 1
I need a sewing guide, basic , starting with threading
Hi! You can find manuals for Husqvarna Viking sewing machines at Another place to look for an instruction manual for your machine is I didn't find anything about replacement instruction manuals on Husqvarna Viking's website--BUT they have a neat feature called The Sewing Room that offers how-to-sew instructions. (
You can also take a look at my Hints and Tips about threading your machine.
Let me know if this helps!
Happy Sewing!
Feb 12, 2010 | Husqvarna Viking 1
How Need to know how to thread the machine and how
They have many different models so threading and winding the bobbin can vary due to your model. I would recommend calling them at: 1-800-474-6437 and see if they can get you a photo copy of your original owners manual.
Oct 15, 2009 | Husqvarna Viking 1
Husqvarna serger won't sew - everything moves, threaded correctly, no results
re-thread and turn the wheel for the first few stiches, also check out this site Husqvarna Viking Sewing Gallery/Ultimate SEWING PlaceWe will gladly answer any of your questions on the Husqvarna Viking or SINGER ® sewing machines, Embroidery, quilting or sergers that we carry, ...
Aug 28, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
1,745 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Bargain Box
Bargain Box
Richard Roth
Richard Roth
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
