Question about Cub Cadet z-force 60
Wont start and wont go up and back and wont turn left or right
Saturn sw2 2000 wont start
did you adjust the plugs to the right spark plug gap should be 8mm, did you put the leads back on the right spark plugs. ? firing order 1342 number one is at front. from left on dispack 4123 this is from left to right. other engine 135 246 number one top left. dispack 146 325 number one is first from left. check this is right aswell.
Mar 24, 2014 | 2000 Saturn SW2
1995 dodge avenger
mark the distributer setting ,loosen hold down nut so it turns firmly,have someone crank over while you turn dist slowly first to right then to left if wont start put dist back to original setting
Apr 27, 2012 | Cars & Trucks
Left turn signal is stuck on
its broken the tab is broken u have to replace the unit which means removing the steering wheel to get to it
Apr 14, 2010 | 1995 Eagle Talon
Ignition switch wont come out
Turn the switch fully to the left. Turn the handles fully to the left. There is a small tab under the switch on the right corner of it, push the tab up, (KEY MUST BE IN)
Mar 20, 2010 | 2008 Harley Davidson FLHX Street Glide
88 benz 560SEL passenger seat reclined wont raise back up
The set on the passager side of my 88 420SEL wont move up, and it make a noise about every 15sec like it is trying to move.
Aug 04, 2009 | 1988 Mercedes-Benz S-Class
Left signal lights wont shut off all back running lights off
sounds like a turn signal switch on the column
Apr 04, 2009 | 1997 Eagle Talon
I changed my transmission fluid on my 1999 mustang tried to start key wont even turn
Changing the fluid would not cause this issue your describing. try turning the steering wheel hard to the left or right to unlock the ignition.
Nov 03, 2008 | 2003 Ford Mustang
Blazer
did you turn the key fully to towards the dash? take the steering wheel left and right slowely and at the same time turn the key back and forth several times slowly. there is a detent inside the steering column that allows you to ingage the neutral safety switch. this should help.....please rate this thanks.
Aug 31, 2008 | 1997 Chevrolet Blazer
Garden Logo
14 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
