Question about Sega Master System Console
There are vertical lines on my tv when i am playing whit my sega master console
Why is there vertical lines on my sega master console when I play video games
    Genius:
  • Sega Master
  • 1,148 Answers
Probably av cables..check them at console and at tv end...if still doin it..find new av cables ..good luck
Posted on May 14, 2016
  • 53 Answers
SOURCE: Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
Posted on Jul 11, 2008
jyackle5
  • 8197 Answers
SOURCE: I need hook-up instructions for my 16 Bit Sega Genesis system con
Go to this link.
http://imageevent.com/gamescans/gamemagazines/segagenesismanual
Good Luck
Posted on Jan 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: My Sega Saturn is acting weird...
try cleaning the glass laser eye with rubbing alcohol and cotton swab. This should fix the problem
Posted on Jul 18, 2009
  • 14 Answers
SOURCE: console not reading disk
Increase the Laser Lens voltage by screwing the orange voltage screw clockwise 35 degrees. this orange laser lens voltage screw is located above the laser assembly inside the console. You will have to take the case off the console.
Posted on Feb 01, 2010
  • 47 Answers
SOURCE: sega master system 2
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or what your console modified to allow it to connect to your TV's AV inlet or S-Video visit www.gameoz.com.au as they stock a huge range of Retro gear.
Posted on Mar 31, 2010
Don't have set up manuals for sega geneis
if it is a plug and play select av port channel 1. if it I s a regular system , put your tv on channel 3 or 4 to play games.
Oct 21, 2012 | Sega Genesis Console
I have just found my old sega master system and would like 2 play it on my plasma tv, however i have found it difficult 2 install. any hits would b helpful
You need to hook it up to one of the inputs and remeber the input being used so you can change your plasma tv to it so when you turn on your sega master system the screen will show up.
Here is a video from youtube that shows you exactly how to do it. Sega Master System plasma hookup.
May 15, 2011 | Video Game Consoles & Games
BOX THINGY
the box is a RF switching box
the lead you require is a phono to ariel lead (megadrive, master system or any old computer will do)
or if you get an old video lead and cut of one end and wire a phono plug to it it will also work.
or you try ebay
http://shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fVideoGamesQ5fVideoGameAccessoriesQ5fVideoGameAccessoriesQ5fJN?_nkw=sega+rf++Master+System++&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=sega+rf&_osacat=0
a basic lead for £2.50
replacments upto £10
both work
Oct 15, 2008 | Sega Master System Console
Sega Master System Controller Port
sounds like the soldering has come loose a bit over the years this tends to happen if you want there is two options open it up and fix the soldering issue or send it in for repair.
I have a shop and it would be $15 plus return shipping costs to fix the unit.
Sep 06, 2008 | Sega Master System Console
White lines on the TV
sounds like the video processor has died
It will be cheaper just to buy a relacment console
if you can't find one locally then try ebay
http://shop.ebay.co.uk/items/?_nkw=megadrive+console+only&_fromfsb=&_trksid=m270
also you may wisdh to consider a RGB lead for better quallity video picture
http://www.retro-cache.com/
Jul 23, 2008 | Sega Genesis 2 Console
Line across top of screen
The line is actually part of an unseen border.
Jul 02, 2008 | Sega Genesis Console
Hey I had that same problem with my sega genesis,on my 52 inch rca hdtv,,its because your using the antenna plug to plug it to your tv,,look on ebay youll find for like 3 or 4 $. a s video for your genesis ,,no more lines ,, way better picture,, very clear,,hope to help,,, thanks
Sega Master System Console Logo
50 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
