Question about Stihl Chain Saw Handle Models 044 046 Ms440 Ms460
Pull cord is pulled out and saw is dead - Stihl Chain Saw Handle Models 044 046 Ms440 Ms460
  • Stihl Master
  • 1,807 Answers
More information needed. You may have just broken the recoil spring in the pull start housing
Posted on Mar 07, 2015
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
U tube chainsaw pull cord wont pull start
Some saws with autotmatic oiling will leak bar oil into the cylinder and cause this. Pull out the spark plug and hold the saw so the oil runs out of the spark plug hole. Pull the starter cord till no more oil sprays out of the hole.Clean the oil off the plug and start your saw. It will smoke more than normal till the extra oil is burned out.
Sep 05, 2014 | Homelite Garden
#pp5020av pull cord
The length of the Starter pull cord is 40"
It can be purchased at www.ereplacement parts.com
I have no affiliation with this site or company. They simply have great prices and also list exploded views of this saw and others.
http://www.ereplacementparts.com/poulan-pp5020av-stroke-gas-chainsaw-parts-c-16962_17147_162366.html
Aug 04, 2014 | Poulan Pro Pp5020av Gas Chain Saw 20" 50cc...
Poulan Pro 295, Hard to pull cord seams like very high compression, even rips back out of my hand, when plug is pulled no problem pulling cord
does it pull hard with Spark Plug out?
Have you been using and then suddenly this happened or was the Saw stored for months and now you are finding it hard to pull?
Dec 16, 2012 | McCulloch Chainsaw Shop Repair Manuals 121...
Saw seems dead, after 8 - 12 trigger pulls the saws turns on (sometimes) but after you release trigger its dead again???
You should check the brushes and cord first but it sounds like your trigger is shot, not an uncommon failure for this tool. With the cord plugged in, hold the trigger on in one hand and bend the cord around in several placed, especially near the boot and push and pull it in the tool. If it comes on, replace the cord. If the it doesn't react to this, check the brushes. Without knowing which model you have, they should be at least 1/4" long, evenly worn and shiney, not burnt, where they touch the armature. If these check out you need a new switch.
Dec 23, 2010 | Dewalt 10.0 AMP Reciprocating Saw
Pull cord difficult to pull..removed from saw it works fine..with spark plug installed hard to pull ..with plug removed (of course there is no compression) ,the pull cord pulls easily..saw worked greatall...
Make sure someone hasn't run this saw without the oil in the fuel mixture. It is possible it is dry and some galling is happening. Or - if this saw is equipped with a compression bleeder (for easier starting), this could be not functioning and you're pulling through the normal compression (which can be a bit feisty!). Check for misalignment of some type having to do with the pull starter - check that the cord spool isn't rubbing on the housing when you pull. Good luck.
Nov 30, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Ryobi 40cc chain saw, pull cord won't turn engine
If it has ball bearings in the rachet mechanism they may be sticking and need cleaning so they move freely.!
Aug 14, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Husky 372 xp stopped working?
you need to check to see if the piston is scored.pull the muffler off the saw and look inside.the piston is right there.if the piston is scored all you can do is change the piston and cylinder assembly.if the saw is new it might be under warranty.check with who you bought it from.most saws have a one year for consumer use.....let me know if this helped...................
May 15, 2009 | Husqvarna Garden
Stihl Chain Saw Handle  Models 044 046 Ms440 Ms460 Logo
64 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
