Question about Refrigerators
GE GSS25kgmc side by side refridgerator side is warm, water to icemaker comes out but doesn't freeze. There is frost on the back of freezer, but only 3/4 way up from the bottom.
  • michael_s379 Jun 18, 2009
    what could I expect to pay for parts on Heater? Motherboard?
  • 35 Answers
BAD MOTHER BOARD OR HEATERS
Posted on Jun 18, 2009
GE gs22jepacc side by side refridgerator
Typically a frost build up would indicate a low charge. Partial freezing as evaporation happens too quickly in part of the circuit. Check the charge.
Nov 16, 2013 | GE Refrigerators
The refridgerator is not getting cold
sometimes when the air flow is restricted cold air migrates back into the bottom of the fresh food side and could freeze the dispenser resevoir which is behind the crisper drawers. Also, just defrosting the freezer is only treating the symptom. Something malfunctione to allow the frost to build up. Either the heater, defrost limiter or defrost timer.
May 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Top of refrigerator is warm and bottom freezes everything it is a side by side refrigerator and the top two shelves of the freezer(along with the icemaker) thaw and melt but the bottom freezes and the top...
poss answer is drain hole/vent blocked,as unit auto defrosts water/vapour collects at bottom and when unit swiches back on it freezes,poke out drain with thin wire with a small piece of cloth dipped in clorine bleach or blow out with air hose.do not use hot water to manually defrost/ clean drain holes every 6 months
Feb 07, 2010 | Refrigerators
Ice melts water drips out of icemaker & freezes in a column
If your model is doing that I would consider looking at the defrost components. Look inside back of freezer for frost building a thin layer on the rear wall. If yes then unplug and remove the rear panel in back of freezer and defrost with a hair dryer. You have and air circulation problem or a defrost problem. Sounds like it's trying to defrost but we need to have a look at the evaporator coils in the rear behind that cover. First let me know what you find and we will go from there, Thanks Sea breeze
Aug 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Unknown water leak from the ice maker, thus freeze build up
the frost on the back wall tells me its not defrosting.this will happen 2 to 3 times a day.if defrost system working their would not be frost.hencethe term frostless.to con firm this sence you defrosted this unit it should work in all ways for a day or 2 lets stop here and you let me know what happens
Dec 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
IS YOUR FREEZER COOLING TO O.F
Jun 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
195 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
