Question about Garden
Transmission not working on 350D truck with code 2003.31
Err 99
Hello hemantp. This error code in this model indicates that the lens electrical contacts are dirty or slightly oxidized. To clean them you will need a common pencil with a clean eraser on the end and a lens cloth.
Detach the lens from the camera and hold it so that the lens' gold contacts are pointing down. Lightly "erase" their exposed surfaces and then clean them with the lens cloth to remove any debris.
Do the same with the gold contacts inside the camera body. Although this is a wee bit more challenging, you can do it by holding the camera so that the lens opening points down. That way no debris will fall inside as you clean. Joe
Nov 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Can get LCD screen to turn on On Canon EOS 350D, working when reviewing photos!
If the LCD works when reviewing photos, then it appears the LCD is working. Can you see the menu when you press the MENU button?
If you're expecting to be able to use the LCD to compose your pictures, you're not going to with this camera. The LiveView ability is a relatively recent development in DSLRS, the 350D works as SLRs have worked for half a century, requiring you to use the viewfinder to compose your pictures.
Oct 17, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D error 5
Does the flash open?
Open the flash and try alcohol or purell hand sanitizer on the hinges and release mechanism. Let it soak in and work it in by moving the flash hood repeatedly up and down
Also check the canon eos 350d service manual from below link:
http://goo.gl/rnauJZ
it will save you money
thanks
Aug 08, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
I have worked all day, thinking Ive recorded the event i covered. In the process I discovered this Error 99. My Canon EOS 350D could only take a successful shop when I zoom an object and go far to make...
If you get err99 with lens then lens diapharm unit goes wrong and its giving er99.
if you getting with body and there is coupleof possiblities.
please descride brifly your camera fault
how and when you geting err99
Aug 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Miller Pro 350D and the exhaust flex pipe needed
you can buy flex hose at auto parts stores and fashion your own bends to replace the bad one
Feb 23, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
For my Canon 350D i'm looking for
Please try to reinstall the software that came with the camera. You can also tranfer pictures using a card reader, which is much easier.
Dec 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Sounds like loose part in Canon 350D / Rebel XT
This is nothing to worry about. The sound is made by the metal linkage inside the flash housing. Pop up the flash and touch the linkage with your fingers. You will see there is a little movement. This movement is enough to make the sound you hear.
Jun 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D CF memory card won't go into slot
It sounds like you have some bent pins in the card slot. Take it to a reputable camera repair and they can look and tell you for sure.
May 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D
I don't have a 350D, and don't have a list of codes but I would guess the error code refers to the Compact Flash card. In the instructions to my camera, a 400D, the solution is to remove and reinstall the card, if there is still a problem, you might have to format the card. Hopefully this will help!
Sep 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
EOS 350D Error Code 5
i have the same prob too on a 350D, in low light conditions, i used to ba able to turn it off and on and then it would work again... but now it wont pop up at all. U can manually pick it up- but i dont think on a regular basis.... mine now is jammed properly, cant even pick it up manually. this seems to be a common prob???
Dec 28, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
