Question about Gaggia Titanium Espresso Machine
Gaggia Titanium, makes hot water but no steam
Hello Experts, I have a Gaggia Titanium which i have owned for about 4 days. It has produced steam correctly until today. Now it will do hot water, but not steam. The pump makes a noise, but apart from a very small amount of water nothing else comes out. Could anyone suggest anything to try?
So far i have tried the factory reset option in the menu but to no avail.
Any assistance would be greatly appreciated.
Richard
    President:
  • 1,618 Answers
Push in on the steam knob, if that works, then the steam valve assembly needs to be replaced, tell the Tech where you bought the machine that you need to get the new stainless steel valve.
Posted on Jun 19, 2009
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
What does it mean when the Gaggia Titanium machine tells you to ventilate the hot water as soon as you turn the machine on?
Ventilate by pressing the hot water button and opening the steam tap. Once water flows freely, close the tap.
If problem persists, its likely to be a broken "steam valve cam"
Apr 29, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium - lack of water/steam!
I have a Gaggia Titanium and the steam valve is leaking can I get repair parts for it
Mar 12, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
No hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
No Steam
Unit sounds like the steam valve and orings have failed.
This causes no steam and internal leakage.
Sep 10, 2008 | Gaggia Titanium Espresso Machine
CLogged Titanium
Love to go over the problem with you. Give me a call at 866-408-9438.
Ask for john.
Cerini Coffee Services
Authorized Gaggia Service center
Oct 14, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
544 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
