Question about Bush 5693D 24" TV
No manual how to set up
Ineed a manual to set tv, add cable box and vcr
images for manual to set tv
PDF]Apple TV Setup Guide (Manual)
https://manuals.info.apple.com/MANUALS/.../AppleTV_Setup...
Apple Inc.Contents. 1. Connect. 2. Configure. 7 What's in the Box. 8 What You Need. 10 Apple TVat a Glance. 12 Setting Up Apple TV. 18 Network Configuration.
[PDF]USER MANUAL - VIZIO
Nov 28, 2015 | Televison & Video
I have an ACURITE 00590A1-RX. My time is off by 10 minutes. i don't have my manual and would like to know how to reset it. If possible, tell me how to download a manual.
From the manual, such as it is:
Set the Time Manually:
If you want to set your alarm clock a little ahead or if the unit ever loses time for any reason, the time can be set manually by following these steps.
1) Press and hold the "CH./SET" button for seven seconds to begin the manual time set mode. (2 BEEPS) The hour will flash on and off.
2) Adjust each setting by pressing the "+" or "-" buttons. Confirm and move on to the next setting by pressing the "CH./SET" button.
MANUAL TIME ADJUST SEQUENCE: hour, minute, year, month, date
This works for me. You have to be sure to keep pressing the CH/SET button for the full seven seconds -- the first beep the the clock gives you will only allow you to set the time zone and DST function.
Aug 25, 2011 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
I have the ET420C that I want to run about 2 hours per day to chlorinate my spa. I cannot figure out anything from reading that manual. How do I set it up to run every day for about 2 hours?
ET420C manual is longer than space allowed for free answer.
Moreover, this manual leaves off key steps and is totally unclear, just as you discovered.
http://waterheatertimer.org/pdf/ET420C-Manual.pdf
On-line manual has page numbers, but pages are not in order, so look carefully at page numbers.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
1) Let me work alongside you while we look go through manual.
2) This timer is simple electronic clock, like alarm clock.
Look at page 3 of manual about setting the clock. (Remember to look carefully at page numbers)
Clock needs to know what time it is at your house right now.
Manual shows 10 steps for setting current time.
You use arrow keys to set clock.
3) Next look at page 4 "program settings"
Use arrow keys to select program number
Program number 1 thru 20 appear on display
In my opinion, it appears that program1 is ON, and program2 is OFF
So program1 will be when you want chlorinator to turn ON
Program2 will be when you want clorinator to turn OFF
The manual is missing this key detail, so look at display to see if it shows program1 ON and program1 OFF ... if the ON and OFF do not display, then timer sets as described above.
Make sure you set same days for ON and OFF times >> if programs have conflicts, then timer will not operate as expected.
How to set programs:
Use arrow keys to select program1 and then press SET
Use arrow keys to select day, and then SET, and then arrow keys to select hour, and then SET, and then arrow keys to select minutes, and then SET.
Repeat steps for program2.
4) Mode appears on page 7 of manual
Again the manual is totally unclear how to set MODE or what buttons are pushed
I have the opinion that you do not set MODE unless you use Countdown or Random feature.
So see if timer operates without setting MODE
5) Add a comment if you get stuck, and I will review manual with you while you push the buttons.
You can add as many comments as needed, and I will respond as needed.
6) For heavy-duty outdoor timer with fewer functions, that is easier to program:
Up to 1/4 Hp, 1000Watts
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
Or
http://www.amazon.com/Intermatic-HB800RCL-Seven-Outdoor-Digital/dp/B001KBZUNK
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 20, 2011 | UPM Programmable Outdoor Timer
Poulan pro bvm200vs, what is the spark plug gap suppossed to be set at?????????????
re: "The plug should be set from the factory check your manual for the gapicon1.png setting"
Chris, If people had the manual do you honestly think they would waste their time looking for the answer online.
Chris - I hope you don't get paid for offering 'Check your manual' answers.
Feb 19, 2011 | Poulan Pro Gas BlowerVacuum ()
Setting Olevia 323 TV picture i.e., color temp, tint, etc
what you will be needing is the manual for your TV. The manual will explain better.
In case you don't have the manual, visit the below link, and click "View/Download", wait a while till the download completes. Go to display settings area of the manual and you will get detailed info about the your TV's display/picture settings.
http://www.manualnguide.com/manual-get/7939/
Good luck.
Oct 18, 2010 | Televison & Video
Bios settings
?manual? when you go into your BIOS at the bottom of all generic BOIS consoles, there are F1 - F12 options. one of these will be: restore to failsafe settings" and the other "optimized settings" the rest you can tweak manually. as far as a manual goes you must be referring to the motherboards manual, and it only touches on BIOS and CMOS settings. good luck.
Sep 25, 2007 | Computers & Internet
Bush 5693D 24" TV Logo
14 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
