Question about Sanyo DRW-1000 DVD Recorder/VCR
How to clean a dvd disc - Sanyo DRW-1000 DVD Recorder/VCR
    Genius:
  • Sanyo Master
  • 1,552 Answers
Buy a "kit", or use a small amount of dish-washing soap, and quickly rinse it off. Put the disk onto a paper towel, to let it dry off.
Posted on Feb 14, 2015
Coby dvd-514 reads wrong disc
Coby DVD 514 Instruction Manual Page 24
use a dvd player cleaning disc,,make sure the disc is supported,it is NOT a blu ray player,only a dvd player,make sure the discs are clean and not scratched
May 09, 2015 | Coby Televison & Video
Sony bluray player flashes wait
see this causes and fix it. God bless you
If your mini DVD player reads "No Disc" after you've loaded the disc, it means the machine isn't reading the DVD. Take the DVD out again and clean it. It's quite possible that the disc is simply dirty and cleaning it will solve the problem immediately.
If you try several different discs and clean them and you still receive a reading saying "No Disc," then the problem is in the laser and this will need to be fixed by a professional.
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid
Sep 30, 2012 | Sony BDP-S300 Blu-Ray Disc Player
Why do dvd players say no disc when there is one in it?
This can be caused by several different things. It may be the read head assembly needs to be cleaned, the disc cannot be recognized. Or it could be a disc format which the player does not work with. Check the owner's manual for compatible disc formats. the Disc may be damaged or needs to be cleaned. The disc may need to be finalized by the recorder it was recorded on if a recordable disc. This is not the case for DVD-video as these are stamped discs.
You can try a cleaning disc but it may not solve the problem.
Inspect and clean the disc and try again.
Having the disc head assembly cleaned may be the answer but the service cost could be more than just buying a new player.
Mar 04, 2011 | Cyberhome CH-DVD 300 DVD Player
Hardly used it & now it doesnt recognize any dvd any clue what could be wrong
Laser eye reading buble,might be dirty,reqiure cleaning or having problems with those DVDs disc's itself like dirts,grimes or cracks and big scratches on those DVDs disc's laser shinning surfacing data's reading side?Check all ur DVDs disc's again u are using,might just require a good cleaning on DVD's discs on the reading data's shinning surface sides,with some dish washing soap?If the DVDs disc's are not the problems.Tries websites like Ebay.com,Amazon.com to buy a DVD disc cleaning kit.By using the DVD cleaning disc,might work,might not.But than u don't have to be littery taking the portable DVD player aparts and used some Q tips,dipping in with some rubbing alchahol to clean the Laser eye reading buble itself.
Dec 01, 2010 | TruTech PVS12701 Portable DVD Player
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
Dvd player won't play disc
There are a few different cleaning kits out there these days for DVD or CD players. I would recommend one that actually has fibers on it so the it brushes the lense of the DVD player. These cleaning kits can be found just about anywhere. Have you tried to clean it with anything?
Jan 12, 2009 | Samsung DVD-V4600 DVD Player/VCR
No DISC message displayed
Clean the lens by soft cloth by hand maually, lens cleaning will solve the problem
Aug 29, 2006 | Panasonic DVD-RV45 DVD Player
Sanyo DRW-1000 DVD Recorder/VCR Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
