Question about Kenmore Washing Machines
Kenmore 110.26002011works fine until it gets to the spin cycle and the lid lock light starts blinking and then turns off and the machine will not spin.
  • 3 Answers
SOURCE: lid locked no power
use a screwdriver in the crevice beneath the lid. Approx 4 inches from each side you will see a 1" silver piece of metal, push the tab towards the back of the machine. Once you get one side loose place something such as a screwdriver to keep it unlatched until you get the other side loose. The top should come open. And there is also a service book inside your washing machine, I fixed mine myself. Look at my other postings. Good luck!!
Posted on Nov 22, 2007
  • 1937 Answers
SOURCE: Kenmore 110.23832100 post rinse cycle spin problems
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23832100
See the Whirlpool service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sometime spinning points to a few places.
First, Kenmore top load washers use a motor coupler to transmit power from the motor to the transmission for agitating and spinning. If the coupler is worn or damaged (the prongs on the motor or transmission shafts are broken) the machine may agitate but may not spin.
Second. These washers use a clutch to transmit power to the tub for spinning. If the clutch is worn, it may not be able to transmit all of the power from the transmission.
Third. These washers are whats called Top load, Direct Drive Neutral Drain. This means that when the washer goes into spin mode, the "neutral drain assembly" has a built in mechanical timer that allows most of the water to drain and then begins the spin cycle.
If the cams in the neutral drain assembly are broken or, as we found onours, a spring on one of the cams is broken, the machine won't spinwithout help.
Forth: These washers use a spin tube, driven by the clutch and connected to the tub with a "basket drive block" If the tabs on top of the spin tube have broken off or aren't inside the slots in the drive block, the tub may not spin.
All of the diagnostics start with pulling the cabinet.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
With the transmission out you have access to the motor coupler and clutch. Check both before proceeding.
If the motor coupler and clutch look OK, I'd pull the tub and spin tube and check the tabs on the spin tube and drive block.
If all else appears OK, the problem points to the neutral drain assembly.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Oct 28, 2009
  • 3 Answers
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
Posted on Apr 02, 2010
SOURCE: I have a simpson EZIset
Ihad the same problem. I cleaned out the blocked inlet to the pump and it now works fine. It would not pump out so would not start to spin until empty.
Posted on Dec 07, 2011
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Blinking lid locked light and green sensor light on machine won't start cycle
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
I have a simpson EZIset 750 7.5kg washing machine, model # 22s750m When the machine fills up and start it cycle everything is fine until it comes time to do the first drain and spin, the lid lock light...
Hi There, I have the same machine with the same problem. I replaced the lid lock switch with the new upgrade kit, though you might need a tec to install it! approx $100.00
Jan 02, 2011 | Washing Machines
Washing Machines Logo
277 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
