Maytag washer makes a clicking noise as it turns what could it be?
  • 1294 Answers
SOURCE: Maytag washer model lat2914aae washer
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line. If available that is.
And dont forget to rate me on this great site!
Posted on Jan 30, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
Posted on Apr 05, 2009
danwan
  • 22 Answers
SOURCE: MAYTAG WASHER THAT WAS IN MID CYCLE AND STOPPED AT
Sounds like the clutch spring is broken. You should have a UC or DC error code showing on the display. Only fix is to replace the clutch assembly.
Posted on Oct 22, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Maytag Neptune FAV6800AW Top Load Washer? makes a
kporter3
See this Clutch repair post if you want to DIY. Is your Wash tub banging around in Spin Cycle? Do you error out of Spin Cycle with dC or uC error code to the LED Console display? You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of Wash Tub movement and the Control Board shuts the Spin Cycle down……..so TDS is working as designed.
The machine will make several attempts to redistribute the load before the error code generation failing with dC or uC error codes. Please let us know what error coded you display.
I or other knowledge owners/DIY’ers or repair folks can help you. Please other forum members chime in for support.
Don’t get hung up in Front Strut issues or other WAG’s. Fix the Clutch Malfunction and your FAV6800A will be happy.
Aka dh1200s….. **** or Rich without the ****
Posted on Jan 03, 2010
  • 33 Answers
SOURCE: timer making clicking noise
You need to change the belt
Posted on Apr 29, 2010
MAYTAG WASHER THAT WAS IN MID CYCLE AND STOPPED AT THE RINSE AND SPIN PART. TURNED OFF THE WASHER AND TURNED ON BUT MAKES A CLICKING NOISE. ALSO LOUD WHEN ITS IN THE SPIN CYCLE. HELP!!!
Oct 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Gas Dryer LSG7800AAW makes noise at start up
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
789f
Aug 03, 2009 | Maytag LSE7806A Top Load Stacked...
Will not start wash cycle
Sound like the lid switch has went out , you should hear it click when the lid is close to an inch of being closed , they are un-expensive and easy to replace and they go out often from use. Easy to find online with your real model number located under the lid.
Phil
The washer with the grind noise is a main bearing going out and may be covered under warr. through maytag.
Apr 11, 2009 | Maytag Atlantis MAV7000
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Washer
TAKE A LOOK AT YOUR LID SWITCH MAKE SURE PLASTIC PLUNGER IS MAKING CONTACT,, SHOULD MAKE CLICKING NOISE WHEN OPEN AND CLOSE LID
Nov 29, 2008 | Maytag Performa PAV2200
Clicking noise
center bearing that holds the shaft is bad and lets the shaft move
Mar 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Jan 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag atlantis washer model# mav6451aww
Your first question I need a little more information. What kind of noise is it? Is it a squeek, or a roar, or like rocks in the tub? The second answer is more than likely a timer problem. This part (Maytag # 22004189) costs around $60 to $75 depending on where you live. Run that part number through eBay for special deals sometimes for those parts. Be sure you find out what that noise is first. If you have a transmission or bearing going bad, that could be a costly repair. Let me know what that noise sounds like, and we'll go from there. Jim
Nov 19, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
