Question about HP LaserJet 1600 Printer
HP 1600 color laser printer--colors are out of sync
The color registration is out of sync on my printer, and I can't see in the online manual how to fix this. Is there a way to force the printer to recalibrate its color registration?
  • Nalin DSouza
    Nalin DSouza May 11, 2010
    have you changed the toner or wiped it so the residue does not stick to the components on the paper disconnecting the colours that come out
  • 72 Answers
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
HP 1600 color laser printer--colors are out of syn - c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a newHP 1600 color laser printer--colors are out of syn - c00659985.gifdge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on HP 1600 color laser printer--colors are out of syn - c00659986.gifage do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quaHP 1600 color laser printer--colors are out of syn - c00659987.gifat is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Posted on Jun 19, 2009
How do i fix door open message on my hp color laserjet 1600
hi you have to check the door closer assembly there is a liver that operate the door sensor
Jul 14, 2014 | HP Color LaserJet 2600n Printer
Printer HP Color Laserjet 2605dn printer is not giving the color prints correctly. The colors are very fade, only black color is fine, rest all color combination are very light.
Your problem have only one solution - open laser/scaner Assembly carefully and clean all mirrors inside whit dry cloth. Dirty mirrors is the most frequently problem for 1600/2600 series
If you dont know how to do that just visit HP service
Mar 31, 2011 | HP Color LaserJet 2600n Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Hp 1600 laser, entire page comes out sligtly black
How old is it?
Page getting dark sounds like the drum getting old.
Mar 12, 2010 | HP Hewlett Packard LaserJet 1600 Printer
What are the starting instructions?
I believe you can download the operators manual from HP's website.
Jul 30, 2009 | Office Equipment & Supplies
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
Red color on hp 1600 not work fine
1. Turn off the printer.
2. Press and hold the (Select) and (Cancel Job) buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init displays, release the (Select) and
(Cancel Job) buttons.
When the NVRAM init is complete, the printer will return to the Ready state.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Manual color registration in Service Mode on CL7200 printer
ok turn the thing on and then open it up and bingo jumbalio!!!
Jan 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Supporting mac
The HP Color LaserJet 1600 does not support MAC. Support for 2600n is the starting point for MAC.
It's not good news but, it's accurate.
Sep 01, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 1600 Printer Logo
1,268 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
