Question about Nintendo Wii Console
No comunacation with remote
Wii console turns on but the remote will not work.have tried other remotes.cables and cords work with other console
  • 152 Answers
SOURCE: need help programming wii console remote
take off the battery compartment for the Wii Remote, and you should see a small red sync button. While the Wii is on, open up the flap for the SD cards, and you should see a red sync button on the Nintendo Wii. While holding the red sync button for the Wii Remote, press and hold the red sync button on the Nintendo Wii. After a few seconds, put the battery cover back on, and test the Wii Remote. Have any questions, feel free to ask. Use the add more details part in your question to ask any more questions. Thank you and have a good day.
Posted on Dec 21, 2007
frankgant
  • 250 Answers
SOURCE: HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Posted on Mar 29, 2008
SOURCE: Wii Remote Control Stopped Working
This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
1) Press the Power button on the Wii console to turn it on.
2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
This procedure must be followed for each additional Wii remote added to your system.
This worked for me, hope it helps you.
Posted on Oct 03, 2008
SOURCE: Brand New Wii Remote not working
tracey.....take the battery cover off the back of the remote....then go to the game system cons and open the front flap to the left of the cd slot (find the red sync button on the cons......press and hold the red sync button next to the batteries on the remote......now just press the button on the game system (do not hold button on the cons.)....watch the remote led lights on the bottom....when they are done blinking there should be a light left on (if this is the second cotroller, it should be the second light from the left that is on).
Posted on Dec 25, 2008
  • 26 Answers
SOURCE: wii remotes not working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
I can't seem to sync my wii controller. All 4 lites are blinking and will not stop. I changed the batteries and tried to re-sync the controller w/no luck. It was just working a few minutes ago.
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
if nothing else works call 1-800-255-3700
Jul 12, 2011 | Nintendo Wii Remote Controller
Tip
2nd wii remote will not connect
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console.
on Mar 04, 2010 | Microsoft Xbox 360 Console
Tip
try this!
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
      Try these steps!
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC" Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
  • on Mar 04, 2010 | Video Game Consoles & Games
    Ok, well me and brother want to play Wii. But we only have one remote, And that remote wont turn on. We are getting like so mad. We've changed the batteries like 5 different times, we've tried Syning it,...
    • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
    • Make sure you are using fresh batteries in the Wii Remote.
    • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
    • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
    • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
    • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
    or if the remote lights up briefly than goes out try this
      Try these steps!
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance. [nintendos help line]
    i hope this helps you and please vote for me
    Dec 06, 2010 | Nintendo Wii Remote Controller
    Unable to setup second hand control , now doesn't recognize either
    Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response. If the problem is not solved, please follow the rest of the instructions on this page. For all Wii Remote issues: If you are experiencing problems with a new Wii Remote, or are having difficulty with a Wii Remote that was previously working properly, please carefully read and follow the instructions on this page. Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info). Make sure you are using fresh batteries in the Wii Remote. The Wii Remote Controller should be used between 3 to 10 feet from the TV. Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote. Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves. Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
    Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common: Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, Try these steps! Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes: With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture). When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4). This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
    Feb 22, 2010 | Nintendo Wii Console
    I can turn my wii unit on with the remote, but cant turn it off with the remote. also I get nothing on the tv screen when I turn it on. we just got the unit today and I know nothing about it
    Try switching the cables connected to the TV to your Wii, plug those 3 pronged cords into a different side. And about the remote thing, Im not 100% sure but i think you might have to open the battery compartment and press the red button to sync with the Wii.
    Jan 10, 2010 | Nintendo Wii Console
    Remote does not respond
    Have you tried re-sync-ing the remote?
      Try these steps!
    Mar 19, 2009 | Nintendo Wii Console
    Wii remote keeps beeping and not working
    try this! I found it on Nintendo.com under support:
      Try these steps!
  • Sep 01, 2008 | Nintendo Wii Console
    Wii fit
    Have had this problem before with wii sports. What I did was turn off the wii console and unplug from the power, leave for a few seconds then turn it back on when the health & safety screen comes up
    4. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    5. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    6. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    7. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    Jun 23, 2008 | Nintendo Wii Console
    Can't get 2nd remote to work
    We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
    This is from www.nintendo.com/wii :
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console.Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    Jun 19, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    10 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
