Question about Contax Normal 45mm f/2.8 Carl Zeiss Tessar T* (MM Type) Manual Focus Lens
Phone will not turn on
Phone will not come on with the charger
My phone was working place it on charger went back and the phone is dead will not come on
The same thing happened to me. It's probably your charger porter. did you somewhat yank the charger out sometime or did it fall of a table or something and the charger yanked itself out when it fell (if it fell). If that's the problem, try putting the charger in the phone & hold the charger up, worked for me. You could also try a different charger or buy a battery charger like I did. There's the link if of the battery charger if needed. I hope this helps!
http://onepluswireless.com/products/universal-external-cell-phone-battery-charger-charges-most-brand-phone-batteries
Dec 03, 2015 | Blu Studio 5.0 Mobile Phone
''WARNING BAD CONTACT OF CHARGER'' shows. where is the problem? charger 100% ok.
Either your charger is not ok or your phone may have some problem.U should the charger which is designed for your phone.U may try wetting the pin of charger with a little much of saliva and then dry it and then connect the charger again.If it again shows bad contact of charger reconnect and if the problem persists then the phone may have a faultu jack.To check your jack connect phone to other charger if it again shows bad contact of charger then this is it your phone has got some problem
Jan 10, 2012 | Cell Phones
Charger is not supported
Make sure that the charger that you are using is compatible with your phone. Trying another compatible charger will help you detect if your charger is faulty. If the second charger that you are using is working with its original phone then there might be a problem with the charger port of your phone. If your phone is still covered with warranty, you can bring it to a license and accredited phone repair shop.
Dec 08, 2011 | Nokia Classic 2700 Cell Phone
Why does my Nokia phone say "charger not supported?
That error message usually occurs when using an unsupported third party charger. An example would be if you bought a cheap "knock off" charger that doesn't supply the correct voltage to the phone. These messages can sometimes occur in error when using an official or supported charger.
If you're sure you're using a supported charger, there is something you can try to fix this error. First, unplug the charger from the phone and the power outlet. Turn off the phone and then remove the battery. Wait about 15 seconds and insert the battery again. Turn on the phone, and plug in the charger to the power outlet and the phone. The phone should now charge.
If it's still not working, you'll need to try to get a new charger. Sometimes, if the phone is still in warranty, you can get the charger replaced for free if it is defective.
Jun 01, 2011 | Nokia 2626 Mobile Phone
Cell won't charge even with a new battery
Try to use or buy universal charger. Get your battery and charge it to universal charger. so that you can use your phone. This is the easy way so you can use your phone.
Jan 25, 2011 | Cell Phones
My n97 is not charging with the charger, only the usb cable. how do i fix this? is it my battery or phone or charger?
It sounds like the charger is the problem. The battery and the phone seem to be ok since you can use the usb cable to charge the phone. I would check the charger to see if there is any visible damage. You can also see if a friend has the same connector (many new phones should due to the EU ruling last year) and check their charger with your phone and their phone with your charger to verify the charger is faulty, but replacing the charger would probably the best solution. Depending on how long you have had the phone, Nokia might cover the charger under the warranty, but I don't seem to be able to find that information.
Nov 30, 2010 | Nokia N97 Cell Phone
My phone won't charge
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
Hi I have N95 and when i plug charger in it says not charging can anyone help
Please check the charger by plugin with some other nokia handset and check if the charger is working fine. If still it shpws not charging with other handset then change the charger as charger is not working
Jun 01, 2010 | Nokia N95 Cellular Phone
The charger slot on the phone does not work when plugged in, think it needs a new port
Why don't you use the charger to charge a similar phone or use a similar charger aside yours to charge your phone to see if it is the charger or the charging port.
If your charger charges a similar phone as yours, it means the charging port of your phone is bad.
But if it does not, the charger is the problem.
If it is the charging port, all you need to do is to replace the charging port and your phone will charge.
Take care.
Apr 21, 2010 | Samsung Instinct Cell Phone
My motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
Oct 04, 2009 | Motorola Mobility Hint QA30 Cell Phone
Contax Normal 45mm f/2.8 Carl Zeiss Tessar T* (MM Type) Manual Focus Lens Logo
Top Contax Cameras Experts
Are you a Contax Camera Expert? Answer questions, earn points and help others
