Question about Whirlpool GR563LXS Kitchen Range
Hot where it shouldn't be
This range gets very hot on the front edge of the stovetop...metal edge surrounding the glass top above the door.
We called Whirlpool who sent out a repairman who agreed it was getting too hot. (Whirlpool said it was normal to get warm.) We returned the range thinking it was defective and purchased another one. It gets too hot too. Not hot enough to leave a burn mark but hurts to the touch and would probably burn my small children. I am returning the second one and purchasing a new range. Has anyone else had this problem.
  • glennschille May 09, 2008
    Have the same problem but on the Kenmore 790.96548602. Sears will not let us return it and we've had 4 Sears repairmen out. Temperature is 117 degrees F.
I just bought a Whirlpool RF265LXTB electric range and have the exact same problem. The one we bought was the floor model, so we thought maybe it was just defective, so we returned it, went to a different store and bought the same model that was new in the box. Brought it home and it is doing the exact same thing.
Talked to Whirlpool and they say it will get warm on the front, but this thing gets HOT! They said they would send out an repairman, but after two different units, I can't see anything a repairman will be able to do to fix it. I wouldn't worry about it too much, but I do have a 3-year-old at home and don't want him to get burned. I think I am going to return it and try a different brand.
Posted on Sep 03, 2008
How do you tighten the oven door handle on a whirlpool electric range
Remove door from range and lay on flat surface inside face up. remove 2 screws at top and screws along bottom edge(4 to 6). The inside of the door should lift off. You will then see the screws that hold the handle on at the top of the inner side of the front half. Snug up the screws but don't over tighten if the screws pass through the glass panel. You don't want to crack the glass.
Feb 28, 2015 | Whirlpool Kitchen Ranges
Replace fuse on ge glass stove top
Maybe the top you can open above switches.
Mar 17, 2013 | GE Kitchen Ranges
How can you take the inner glass out of the cooker door to clean the inside?
Lets see if we can help.If you open door slightly and look on the top of the door edge,you will see a metal plate going across the full width of the door.If you gently push this towards the inside of the cooker,pushing from each outer edge,it is held in with 2 spring clips.When you have this clip off the glass will just slide up and out for cleaning.The glass will normally be marked for correct replacement, (eg.To Inside and or top).Be very careful when lifting out glass and also look out for little rubber buffers that protect the glass when it is refitted.
Hope this helps.
Jun 25, 2010 | Electrolux Insight EKC6049X Stainless...
I have a Jenn Air Electric stovetop with a glass top (Black) model # FCE 30600A One of the burners is nor working. Can I remove that glass top and repl;ace the burner?
Yes you can, at least I removed mine on a Kenmore. Be very careful as the burners are very delicate and even more so after they have aged.Look under the edge at the front for 3 screws. The top should pull out slightly and lift.
Apr 11, 2010 | Kitchen Ranges
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Electric stovetop gets VERY hot
Oct 20, 2009 | Maytag MER5775Q Electric Kitchen Range
Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Mar 15, 2009 | Maytag MER6772 Gemini Electric Kitchen...
My oven door shattered. i bought the glass and the outer trim. i need help installing it
This job is best done by two people, one to hold the glass in place, and the other to operate the screwdriver and position the handle and trim pieces.
The glass is held in place by the handle assembly at the top and a metal track at the bottom.  You remove the glass by removing the handle. Open the door part way until you have access to the back of the door.  The door handle is held in place by two screws on the back (the oven side).  Remove the screws, taking care to hold the handle in place.  Be sure to brace the glass, then slowly move the handle away from the door frame.  Remove the glass.  The side trim pieces will probably fall away from the door frame, although they will probably not fall all the way out.  My advice is to carefully remove them.  Be careful; they have tabs on the bottom edge that hold them in the door frame and these tabs are easily broken.  If yours are still in one piece you might just reuse them.
Remove the old glass panel and clear the bottom track of any debris.  Put the new glass panel in, beginning with the bottom track.  Set the oven handle on the top edge of the glass panel; there are tracks on the back of the handle assembly the top edge of the glass fits into.  Bring the handle toward the door frame, taking care not to let the glass panel slip out of the tracks.   The door handle has two collars that go through holes in the door frame.  Once you've got the collars through these holes, you can put the two screws back in that secure the handle to the door.
Take one of the side trim pieces.  Each trim piece has a narrow edge and a wide edge (like a capital "L"), The narrow edge faces the front and the wide edge faces the side of the door.  Each piece has a corner edge with a little tab sticking out.  These face down.  The opposite end of the trim piece has recessed edges. These slide under the edge of the door handle.  You want to insert this end first, then work your way along the length of the trim piece pushing the narrow edge between the door frame and the glass panel.
Here's the tricky part.  To get the bottom in, the best thing to do is to open (or better yet remove altogether) the drawer beneath the oven to gain access to the screws that hold the bottom track of the glass panel to the door.  Loosen the screw that holds the track in on the same side as the trim piece you're working on; the screws are on the bottom of the track about 1 inch in from the edge. Loosen the screw slightly and pull down on that edge of the trim as you push the trim piece in behind the glass.  Repeat until the trim piece tab slips through the hole for it on the track.  Tighten the screw back in place.
Repeat this process for the other trim piece. If you're patient and gentle, it shouldn't be too difficult.  I just did this myself today (2/7/09).
Good luck.
Jan 24, 2009 | Kitchen Ranges
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
We cleaned the inside of our glass door today, it was easy but unfortunately we had a problem. Hopefully this will help you avoid the problem we had which shattered the outside glass on the door.
1) Open the door all the way, but put some support under the door to prevent it from dropping. It helps if you have someone else support the 2 halves of the door.
2) There are 2 screws on the top inside of the door. Carefully loosen both screws. This will detach the front of the door from the back and allow you to clean it. BUT, this is important: Do not allow the inside of the door the swing back toward the closed position as this will cause the glass to shatter.
3) Open the 2 halves of the door only enough to get your hand in and clean the glass. Avoid moving the doors while cleaning and avoid excessive pressure on the clean when cleaning.
4) Once you finished the cleaning carefully place the doors back together and tighten the screws.
Apr 30, 2008 | Kitchen Ranges
Whirlpool GR563LXS Kitchen Range Logo
130 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
