Question about Fisher and Paykel Washing Machines
Trips circuit breaker as soon as it is turned on at wall
  • 41 Answers
The power lead inside the machine may have been rubbing or cut on something. needs to be dismantled to inspect
Posted on Apr 16, 2014
SOURCE: LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Posted on Jan 31, 2009
  • 135 Answers
SOURCE: Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Posted on Jan 22, 2009
  • 183 Answers
SOURCE: Washer Tripping 20 Amp Breaker
probably a faulty heater.
Posted on Dec 27, 2007
  • 1531 Answers
SOURCE: Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Posted on Sep 16, 2009
mkh5094
  • 145 Answers
SOURCE: Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Posted on May 02, 2010
Can the motor control board cause the house circuit breaker to trip?
It's unlikely. An internal fuse would blow first, I'm assuming. If you've diagnosed this far you sound capable of continuing. Electricity is dangerous!!! I would remove all things from the board, 1 by 1 plug each component into board until the breaker trips. That should pinpoint what is tripping breaker. I would assume a motor.
Apr 04, 2017 | Heating & Cooling
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
What is causing washing machine to trip circuit breaker?
Your water inlet valve is faulty
remove the wires and see if it still trips
Aug 28, 2014 | Bosch Washing Machines
Replace main control board
Is the wall receptacle defective? Have you plugged something else into the same wall receptacle without circuit breaker activating? Test with another appliance that also has the third round ground prong. If this is not the problem then yes an electrical short exists within the treadmill, inspect the cord itself for loose prongs, there may be liquid damage inside from a previous liquid spillage which would cause an electrical short.
Dec 22, 2013 | Nordic Track Exercise & Fitness
As soon as I turn on my heating unit, it trips the breaker. The heating unit will come on and in a matter of a second, it trips the breaker. What's wrong and what can I do?
Heating element short circuited. Or wires to heater may be loosen or short circuited. Check your breaker also. Sometime, due to defective breaker also it happens.
Dec 15, 2010 | Heating & Cooling
Dryer Repeatedly tripping circuit breaker, Apartment Maintenance man said we had a defective dryer, Bought new dryer and 5 minutes after first load was put in it tripped the breaker, Maintenance man...
You probably have a bad plug connection, make sure all the wiring in there is tight, you may see signs of arcing. A bad connection causes resistance, and therefore causes the breakers to trip. It is best to replace the receptacle on the wall outlet with a new one because the problem will just resurface again soon.
Aug 12, 2009 | Dryers
Two 15 amp arc fault breakers installed on two adjacent circuits. One works fine - does not trip. The afi breaker beside it trips as soon as it is flipped on. We tried switching circuits, but both circuits...
It's possible that the first breaker that you said does not trip - it could be that breaker is failing to trip on a bad circuit. That is, it could be you have a bad circuit but that first breaker is not detecting it and pretends everything is OK. If your new breaker trips on the first breaker's circuit, the curcuit it probably bad and the breaker in not working properly. The most common problem for failed circuits is a stray ground wire in a box somewhere in the curcuit resting against a hot or neutral wire. You'll have to take apart every connection on that curcuit to find it. Not fun.
Jun 14, 2009 | Siemens 20Amp 1-pole arc-fault circuit...
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
