Question about Gestetner DSc224 Copier
My Gestetner 3235 will no longer work.
The display says the used toner case is full. I no longer carry a service contract on this machine. Do you know where I may find a free service manual on line? Or do you know what I should do specifically to fix this problem? Thanks for your attention.
  • Gestetner Expert
  • 398 Answers
Open the duplexer, open right door the brown belt thing is the transfer and waste toner assy, on the front side of this is a 1.5 inch handle that needs to be lifted to the upright position and rock it away from the copier and place it on newspaper, take the 2 springs off lift the brown belt upper portion up releasing the tab on the front side. now you need to "dump" all the waste toner from the lower half. and reassemble, rember to put it back like it was.
-Carl, please let me know if this helps.
Posted on Jun 27, 2009
    President:
  • 3,085 Answers
Don't know too much about Gestetners, but open the doors (usually the front door) and look around for a plastic bottle for waste toner. Spare ones USUALLY come with the toner carts.
Posted on Jun 19, 2009
6030 display
KM-6030 or FS-6030. if it is the fs open the fron door, remove the waste bottle and replace it with a new one (they come with the toner). if it is a KM or CS 6030 that should be covered under your service plan. if you are running a segment 3 machine without a service contract you need to reevaluate your situation.
Nov 28, 2013 | Kyocera Office Equipment & Supplies
After installing an off brand cartridge for a Gestetner copy/fax machine, it only printed half pages and the printing was poor. They said the brand name cartridge was no longer available. please...
There are many different companies that sell compatible toner, and the quality varies greatly. You should try getting your money back from the company you bought that toner from, and find a new supplier if you can't get it from Gestetner. Premier is a company that sells compatible toner for many different machines, and they usually get pretty good reviews.
Aug 05, 2010 | Gestetner DSm620d All-In-One Laser Printer
Please help we are changing the toner on our copier machine and got an ERROR MESSAGE: used toner case is full.
the waste toner box is located beneath the front cover ( the cover that has Canon and model number ).
Open toner cover and you will see one screw wich you need to remove.
Then, on left side of toner, on top of the front cover, few milimeters from edge is second screw wich you need to unscrew. Usually is covered with white/grey cork made of rubber.
then remove cover, by pulling it in left side then towards you.
Big white box is waste toner container wich you need to clean/empty it.
Hope that helped!
Jul 26, 2010 | Canon ImageRUNNER 3235 Black and White...
My gestetner 2712 has ran out of toner. i have replaced the toner, the machine takes a while to load and then comes back with load toner again. Why would it not be registering a full toner bottle?
GESTETNER 2712 PROBLEM USUSALLY SIMILAR TO RICOH 2022/1022/27 PROBLEM IN WHICH INLET IN PCU AT LOAD TONER OUPUT. wHAT YOU CAN DO ,TEK OUT THE PCU IN CHECK IF THE PCU TONER INLET IS BLOCK EITHER BY SEAL OR DUE TO INLET CLOSER MALFUNCTION CAN BE REPAIRED IF YOU HAS EXPERIENCE OPENIG UP THE PCU
Apr 06, 2010 | Gestetner 2712 Digital Imaging System...
Gestetner 3235 copier speed only 35cpm it true that
replace the board and the main motor and the polygon mirror motor( not recomended)
3245 45cpm
3235 35 cpm
Oct 30, 2009 | Gestetner Office Equipment & Supplies
Hi again! i have a multifuctional machine gestetner dsc428. i print 500A3 full black with b/w print option from the driver checked. After i finished the prints my machine shows a message on screen tha...
Are you using third party toner, or OEM? Toner cart has small chip on it that the machine reads and is being told not OEM toner
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 09, 2009 | Gestetner Office Equipment & Supplies
Gestetner 3245 (used toner case nearly full)
most likely it will be on the right rear. look for a door w/ a couple of screws, there is a white plastic container, empty or replace and put back. should clear on it own when done.
Sep 26, 2008 | Office Equipment & Supplies
Gestetner 3245 error
Your machine must be serviced by a trained technician. Cleaning out the used toner requires disassembly and specialized knowledge and equipment. If you keep using the machine, it will stop working completely when the used toner is full, and will not be usable until the used toner is cleaned out.
Gestetner 3235 Mono Photocopier
I believe that model is fairly old.... Dosen't the control pannel have a red light showing what door or cover is opened??? Try all the doors and covers and look in the last spot you pulled a paper jam from...
May 19, 2008 | Office Equipment & Supplies
344 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
