Question about Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC
Item with same key has already been added - Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC
How can I bypass the lid lock model # NTW47018QO
the lock function was added to elimimiate the danger of someone sticking there body parts inside machine (they can kill a human or pet) while its operating this is a safety function and really should not be bypassed unless in very special uses , this function used to be done by a lid switch that shut power off to machine , the lid lock now is easy to disengage just press the stop button in as soon as machine stops moving the the lid should unlock allowing you to open it to Add/remove items , I do warn folks that if any items are added after fill step the auto water level sensor has already made its calculation of needed water so what's in there after more clothes are added will not have sufficient water level to clean properly resulting in disappointed washing results
Sep 23, 2015 | Amana Washing Machines
Replaced toner and waste toner container, but there is still a 'add toner' red light
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key.
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.
6. Enter the maintenance item number (130) using the up/down keys.
7. Press the enter key. A selection item appears.
8. Select On using the up/down cursor keys.
9. Press the enter key.
10. Turning the power switch off and back on. ADDING TONER is displayed and installation of toner starts.
11. After approximately 15 minutes, the installation is completed and the machine becomes ready.
Jan 08, 2011 | Kyocera Copystar CS-1820 Black and White...
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
How do I change the font in "Sent Items"?
Hi there.
You can't change the font in sent items because you already sent email in the font you chose to send them in.
If you send them in large font it should show that in the sent items folder.
Jun 12, 2009 | Microsoft Office Professional 2007 Full...
INSTRUCTIONS FOR THE KEYS ON THE CALCULATOR
To get a subtotal when adding, finish entering the last number before the subtotal, hit the +, then hit the diamond/pound sign key (just above the 7)
To get a grand total when adding, finish entering the last number in your list, hit the +, then hit the *.
Jan 14, 2009 | Casio HR-100TMPlus Calculator
Editting Categories Colors
What program is this happening in?
May 09, 2008 | Palm TX Handheld
Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC Logo
80 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
