Question about NEC DT330 - - Phone
NEC ARROW AND HEADSET SHOWING ON DISPLAY - NEC DT330 - - Phone
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Mar 02, 2018 | NEC NP410 3LCD Projector
The display screen on my DTU 8D is all black
Try adjusting the display by using the arrow keys on the bottom right of the phone. The phone must be idle to do this.
Jul 07, 2009 | NEC Electra Elite 32D-1 Corded Phone
How to setup a headset for a NEC DTU-162? I've
Not sure detailed steps can be posted here. check out ldtsnj.com
Jun 03, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Display contrast - too dark
You should be able to adjust LCD contrast when phone is idle, just use the up/down arrow button to adjust it (don't go off-hook). If you have background music set, the above procedure will adjust the music volume instead. You can turn Background music on and off by pressing <Feature>,2,6 when your phone is idle. Alternatively, you may press <Speaker> 6,0,2 and then use the UP/Down arrow key to adjust LCD contrast.
Dec 11, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
Nov 11, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Oct 12, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC DTU 16D-2 issue
hi,1.to adjust the ring tone volume. from your phone set,press speaker dial 601.press the arrow key up or down to adjust. 2. if your station is programmed as system admin phone,then you can press feature 80 feature.to toggle between day or night.do not press speaker button while doing this. 3.the headset port need to be program,or you can do without it,by purchasing the headset came with the adapter and connect thru the handset cord. the new model is DTH-16D. CAN email me if you need a new phone, sjohnnyh@yahoo.com
Sep 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Dterm80 NEC phone
How do I get the following off my display?
MSG >>> In-Mail #2
Sep 12, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC DT330 - - Phone Logo
21 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
