Question about Sonim Xp1300 Core Ip-68 Toughest Phone Ever Build
Sonim ip 68 factory reset code - Sonim Xp1300 Core Ip-68 Toughest Phone Ever Build
HELP my new sonim locked me out while I was trying to create password.. My IMEI is 35169603-111206-3 Missing lots of work calls Andre Miller
All you need to do is contact your phone provider for an unlock code to this issue. If your unable to contact them, you may download an approved list from the internet to use while attempting to unlock the cell phone again.
Jan 21, 2011 | Sendo Sonim XP1 JCB phone extreme...
My Sonim XP3 Quest Pro write sometimes fileerror.return when I have an incoming call up and it is not ringing
Hi Riisbjerg, you could try to reset/clear flash the phone. That should take care of the problem, but it also erases ALL settings and phone book entries from the phone, so it is best to make a backup of the phone bookwith the PC tools software.
The software can be downloaded from http://www.sonimtech.com/support/downloads.php
Reset: Please try to reset the handset memory as below:
a. After Powering ON the phone
b. press #20070114# from phone idle screen and press dial key.
c. Message comes up as " Do you really want to clear flash? "
d. Select OK. After reset is finished, you can see the message "Switch off the mobile by any keys".
e. Switch the phone off, then remove and reinsert the battery and Power ON the phone.
Once done, please restore the handset to factory settings:
a. Power the handset on
b. Using the menu buttons, go to Settings (General Tab) -> Default Settings.
c. Press the OK button to confirm
d. Power the handset on again
If this does not help, please send an email to the Sonim support team: support@sonimtech.com
Thanks!
Andreas Sonim Customer Service
Jan 15, 2011 | Cell Phones
How to unlock sonim xp1 mob phone.
Hello,the truth is that you can unlock the phone ,but you can't unlock all phone for free.The payment sites are very cheap you could try it out and see.You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can get a free unlock code.
Visit the links below if you are interested in buying the unlock code:
(hubpages.com/tag/cell+phone+unlocking/hot)
and
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
May 07, 2010 | Sendo Sonim XP1 JCB phone extreme...
I have a samsung r450 and i switch from a nam1 to a nam2 and now they are asken me for i do not know what should i do?
Here do a complete factory reset and start over with your setting again.
FOLLOW THIS TO THE LETTER YOU'LL BE FINE.
Let me know how it works out for you it did for mine
Samsung Messenger R450 Master Reset Enter Code : 47*68#13580 Then enter code: 185
Oct 26, 2009 | Samsung Cell Phones
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
D-link dir625
When your laptop is working, check the ip address.
Open your DOS PROMPT, type iconfig then click enter. If your ip address on the laptop is 192.168.x.x, that means that you are getting your internet from the router. If your ip address is (just an example:68.x.x.x, that means that the router is not functioning properly.
If the laptop ip is 68.x.x.x(just an example), make sure that your comcast modem is connected to the INTERNET PORT of your router.
You just bought your router so the best way to deal with this problem is call Dlink tech support so they can walk you thru the router configuration.
Good Day
Mar 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
Magnavox mpf 68
Hi its easy, just press and hold av/tv button and then press the on off button on the remote, my kids turn it on all the time . Regards Paul
Jan 08, 2008 | Philips Magnavox 27MS343S 27" TV
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
Sonim Xp1300 Core Ip-68 Toughest Phone Ever Build Logo
253 people viewed this question
Top Sonim Cell Phones Experts
William Alequin
Are you a Sonim Cell Phone Expert? Answer questions, earn points and help others
