Question about Canon ImageRUNNER 330s Copier
Canon Copier imagerunner 330s
How do I reset or remove the USER ID and PASSWORD function on this copier that has just been donated to our church?
  • 4,889 Answers
Read this thread...You might need some help from a technician..
Posted on Nov 02, 2007
Canon IR 330s - i have error message E004. how do i clear it?
This is an error for the thermistors in the fuser not reading temp correctly. Go into service mode by the standard Canon way - Additional Function key, 2 & 8 held down at the same time, then Additional Function key. Press copier, function CLEAR, ERR, then OK. Power cycle the copier and the error is reset. Again if the error come back you will have to check the fuser assembly, heat lamps, thermistor, thermofuse, etc. There is a problerm thsat needs to be fixed and continuing to reset may do major damage to the copier.
Jun 22, 2011 | Canon ImageRUNNER 330s Copier
I would like to Reset/Retrieve Password for Copier Setup Canon, ImageRunner canon ir 2318
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Jun 29, 2010 | Canon imageRUNNER 2200
Canon Imagerunner 330S toner replacement
Unlike most toners, this one snaps on the top and the toner is transfered into a holding tank so you don't actually remove anything from the machine.
Jan 07, 2010 | Canon ImageRUNNER 330s Copier
Installed new department code access without any department codes
If you can get into service mode...try COPIER, FUNCTION, CLEAR THEN CHOOSE PWD-CLR, awitch off then on.
Mar 23, 2009 | Canon ImageRUNNER 330s Copier
Admin password for Canon ir2270 MFC
Mar 17, 2009 | Canon Office Equipment & Supplies
Imagerunner 330s id
remove all the ids you stored in the machine. even one id is left means it will ask for p/w.
Feb 18, 2009 | Canon ImageRUNNER 330s Copier
Imagerunner 330S - just received this copier as a donation (we're a small nonprofit). Machine claims there is a paperjam in paper tray and side drawer. Doesn't seem to be paper in either location. Any...
check whether any sensor spring will open under stack bypass area, under toner area or under back panal fixing area or any short piece of paper in way of paper feeder
Feb 09, 2009 | Canon ImageRUNNER 330s Copier
Start with service mode, Additional functions(looks like * key), then 2,8 together, then addit. func. again. Has to be a fluid motion. If done right you will see a screen with copier, and whatever options the copier has. Hit copier key. Hit function key. Hit panel key. Hit touch key option, hit OK. Then touch the nine + signs. once complete. press reset to get out and test results. Hope this helps.
Jun 13, 2008 | Canon ImageRUNNER 330s Copier
Canon Imagerunner 330s - Stack Bypass
you can select for tray (letter size ) as default in paper settings
the stack bypass paper sensor may be broken and is active all the time
Jan 29, 2008 | Canon ImageRUNNER 330s Copier
267 people viewed this question
old marine
old marine
