Question about Stihl Fe 35,40,55 & Ec70 Electric Trimmers,edger
String replacement What size string do I need for an Fe55 stihl electric trimmer?
2 Suggested Answers
BaronVonNuke
  • 1915 Answers
SOURCE: How do I change cutting string on a model Fe55 trimmer
HOW TO Replace STIHL Grass Trimmer Line
Posted on May 31, 2015
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
WHAT SIZE TRIMMER LINE FOR STIHL FSE 60
You should use .95 diameter line or larger but it is not critical.
Aug 07, 2014 | Stihl Fse 60 Electric String Trimmer
Need to view schematic for Stihl FS130 String Trimmer
there isn't really any schematic we can give for a list of part numbers but any dealer anywhere should be able to find what you need. Just give them a call and tell them what you have and what you are looking for
Mar 08, 2013 | Garden
Restring stihl fe55
easy spool head or not??? your owners manual has directions.
Sep 02, 2012 | Stihl Fe 35,40,55 & Ec70 Electric...
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
String for a Poulan Pro PPB330
Pull your spool off, and look next to the notches on the bottom of the spool. The decimal number is the size of line that you can use. Some spools will have more than one size listed; they can use either size.
Best regards, --W/D--
Aug 21, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
String breaking
Check to ensure that the string is the correct size as specified in the owners manual. If ok check age of the string. If old it has a tendancy to be brittle. If new and supple try letting the trimmer get up to full speed and let the tip of the string do the cutting. Avoid taking on too much at once with this trimmer as the electric and battery trimmers are not as powerful as their gas counterparts. I hope this helps.
Sep 11, 2008 | Toro& Electric String Trimmer
Stihl Fe 35,40,55 & Ec70 Electric Trimmers,edger Logo
70 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
