Question about E-Machines eMachines Desktop PC
My boot devices are disabled - E-Machines eMachines Desktop PC
    Sergeant:
  • 206 Answers
Hi
Normally for Pcs and laptops the booting devices can be found in the CMOS/BIOS settings, when you start up the pc/laptop you normally press esc f1 f2 etc, this allows the user to enter into the CMOS/BIOS setting.
Under the Boot tab you will see all the devices you boot from they will be enable/on or disabled/off check them to see which devices are on and off.
The last tab has a load default option if you select it and exit and save these changes it will automatically enable all the default devices in order.
Your pc/laptop should boot up normally now
Cheers
Posted on Mar 31, 2016
Disable dhcp
You may need to go to BIOS setting and disable PXE Boot option. It should be under Integrated Devices, or the Network Device section of BIOS.
Regards,
Kaushik Patel
Aug 27, 2013 | Dell Computers & Internet
HP DL160 g6 need to activate boot from DVD
Hi Fyamine,
While booting go into the BIOS, use either the dedicated keys or +/- to enable/disable the CD ROM boot ( in the Advanced section of device management), then go into the advanced boot tab and change the boot order (it should be CD->HDD->Pxe->Disabled by Default). After that, restart the server and wait for it to boot from the disk.
Dec 24, 2012 | Compaq ProLiant DL380 Server
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
Usb ports not powering a keyboard or mouse
Best would be to determine whether any changes was made to the system prior to the error starting. Changes would include Windows updates, driver installations, hardware installations or software installations and upgrades. If you are unable to determine this, then boot into Safe Mode and view the System and Application Logs. Stop any services which may report that it can't start or has some or other error. If Software upgrades has been done, do a roll back on these and remove any newly installed hardware. If no upgrades where done hardware or software wise then disable all devices which is not required to boot the system and disable all services and applications loading on startup which is not required to boot the system. If the system boots after this then enable each program and devices separately ( Re-booting the computer after each one is enabled ), until the system fails. Disable the last device enabled before system failure and continue the process until finished leaving the devices / programs which causes system failure disabled.
Feb 22, 2010 | Acer Aspire T690 (AST690UP820A) PC...
On board pxe booting problem
Hello
If i understand well you want to disable it
to disable it when you start your computer press del until you will see BIOS(a blue screen) then it should be in the `Boot Device Priority,' and disable the `boot from Network device'(PXE boot) option.Save your changes and restart
Good luck
Jan 13, 2010 | Intel DG31PR Motherboard
Motherboard is starting slowly
go in bios setting, disable floppy disk drive, set first boot device hdd and disable lan boot rom.it will make fast your motherboard's booting speed.
Oct 19, 2009 | Mercury KVM800M Motherboard
Boots usb first
Hi apicard91
Go into your BIOS and check your boot sequence or boot menu.
there should be a option to disable booting form either a "removable device or external device or usb device"
Just disable that option and then you good...
Please rate the service you recieved
Apr 24, 2009 | Computers & Internet
I am having hp pavilion dv2000 notebook pc.
try to go into BIOS by pressing F2 or Del while booting...
then change boot device order as 1st boot device as Hard disk
Dec 11, 2008 | HP Pavilion dv1000 Notebook
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Apr 28, 2007 | HP Compaq dc5000 PC Desktop
E-Machines eMachines Desktop PC Logo
47 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
