Wf8300sw spin cycle the drum appears to out of balance also the drain pump rattles when in operation very annoying.any suggestions
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
Posted on Sep 26, 2007
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
SOURCE: rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Nov 12, 2008
  • 33 Answers
SOURCE: LG TROMM noise during spin cycle
Dear Customer,
for ur water not drainin out, please do the the followin checks
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
  • n for ur rattling during spin cycle please do the followin checks..
    Please read our safety information before attempting any testing or repairs
    Before working on the washer, unplug the appliance or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
    A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive noise. There can be several causes and the problem is worse with some machines more than others.
    The most common cause is an unbalanced wash load. Open the lid and when it comes to a stop, redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit.
    A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See our article on how to level your washing machine.
    The outer tub is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons may begin to wear out and not support as much weigh as needed.
    Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be called for.
    Another common cause for excessive movement is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.
    There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
    • General tips mentioned above
    • Balance the load
    • Level the machine
    • Inspect the water pump for a blockage
    • Inspect the coupling
    • Inspect the transmission
    • Adjust the drive belt tension
    • Check the motor bearings
    • Check the drum brakes
    Please rate this solution.Thank you..
    Posted on Dec 16, 2008
    SOURCE: Kenmore Washer Spin Issue - Need help troubleshooting
    Hi, I have the same machine and same problem and I fixed it this morning I felt something with my hand at the bottom of the drum. It was a nail that went diagonaly insibe one of the drum holes right under the outer surface of the spinnner, right now it is working perfectly.
    Posted on Jun 05, 2009
    Frigidaire GLTF2940ES Front Load Washer stop spinning
    Hello Kathy Murphy - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs to be cleaned. Will the drum manually rotate (when it is not in use)? If it does not, then the washer drum may not be balanced and/or possibly have a broken shock. Is the door securely latching? Supposing it is not, then the door latch assembly will need replacing. However, since it is such a complex unit, I strongly suggest contacting a professional to accurately pinpoint any potentially more serious issues like the timer, pump or control board not communicating correctly.
    Jan 27, 2013 | Frigidaire GLTF2940ES Front Load Washer
    Samsung WF7700N6W1 washing machine not draining
    Could be a sock or something between the 2 drums that moves over the outlet hole from the drum when upright and trying to drain but moves away when machine is on its side. Get a flashlight and look through the holes in the inner drum and you may find the culprit.
    A coin may also be stuck in by the pump blade, not always easy to see but worth a look.
    Dec 22, 2012 | Samsung Washing Machines
    I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    Aug 05, 2010 | Frigidaire Washing Machines
    The machine runs but won't spin.
    Does water remain in the machine at the end of the wash cycle? Does the water pump run when it is supposed to? If not, the pump may be jammed with debris or the motor is defective. Can you drain the water by lowering the drain hose to floor level and into a bucket or pan? Does this allow the spin cycle to proceed? It is normal for the machine to test for spin balance (it will agitate further if it is not balanced). Hope some of this helps!
    Apr 09, 2010 | Hotpoint WMA32 Front Load Washer
    Water leaking and loud noise and rattling on final spin cycle
    Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
    Eric
    Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
    Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
    • Hi,
    • Try these:
    1. Balance the load
    2. Level the machine
    3. Inspect the water pump for a blockage
    4. Inspect the coupling
    5. Inspect the transmission
    6. Adjust the drive belt tension
    7. Check the motor bearings
    8. Check the drum brakes
    please rate my suggestion...
    May 20, 2009 | Kenmore Washing Machines
    Machine dosent seem to drain model #lat8840b maytag
    my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
    Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag Neptune out of balance on spin cycle
    Hi, try to check the spring virator support might pollout from slot or hole connected, some adpter are rusted spring replace it are also available in appliances store.
    Feb 15, 2008 | Washing Machines
    Washing Machines Logo
    22 people viewed this question
    Top Washing Machines Experts
