Question about Bose Wave Radio
Lcd display very dim
Is there a way to increase the brightness, you can vie wit but only up close.
  • DigidocTN
    DigidocTN May 11, 2010
    It has a sensor to adjust to room lighting. If you have the room bright, do you get a brighter display? That sensor would be hard to find, and Bose will charge you $100 for the repair. Best of luck with it.
My clock display is extremely bright, is there a way to dim it? thanks Natalie natalie1959@gmail.com
Posted on Sep 06, 2009
Screen is vry dim if u shine a light on it u can barely see it is there a easy fix or do I need to go to a shop
Shannon Wagner.,
You can try increasing the brightness using the FN keys on your keyboard. <Fn><F11> Decreases brightness on the integrated display only (not on an external monitor). <Fn><F12> Increases brightness on the integrated display only (not on an external monitor). If needed start the computer and tap the F2 key to enter the bios. Navigate to the Video Section and you will see where to adjust brightness.
LCD Brightness This option (represented by a slider bar for On Battery and On AC) sets the panel brightness when the ambient light sensor is off. Thank You,
Dell-Jesse L
Feb 20, 2016 | Dell Latitude E6320 Laptop Computer 250 GB...
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display ' eHow.com http://www.ehow.com/how_5818403_adjust-brightness-ibm-thinkpad-display.html#ixzz277iQ4g48
Sep 11, 2012 | IBM ThinkPad G41 Notebook
Display is dim and I cant find a way to brighten it
press and hold fn, then press F7 to reduce brightness and F8 to increase brighness.
That is Fn + F7 or F8.
Take care.
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
My LCD monitor has a dimmed display
You should be able to increase the brightness by holding down the blue "FN" key and finding the blue brightness buttons (usually the up and down arrows or two of the F keys above the numbers. The brightness buttons usually look like a sun with a up and down arrow.
Mar 18, 2009 | Hitachi 14.1 IN. (1400 X 1050) SXGA+ TFT...
COMPUTER LCD BRIGHTNESS
go check your model # brand , and try to reemplace a LCD LIGHT DISPLAY INVERTER, it should be a small light bulb located inside of your lcd laptop
Dec 03, 2008 | Computers & Internet
Backlight only stays on for a few seconds on compaq c700 that is only a year old
When the external AC power supply is unplugged from a notebook, the LCD display will dim to conserve on battery power. During times of heavy battery power operation; such as during the startup or boot process, the display may be very dim or barely readable. If the display remains dim when the notebook is operating on the Windows desktop, follow the steps below to resolve problems with display brightness Restart the notebook with AC power Follow the steps below to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the power button for 5 seconds.
  3. Press the power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected, try changing the LCD brightness. Adjust the LCD brightness using the function keys From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8 key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers ( f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be familiar. Check the movement of the Lid Actuator switch The Lid Actuator switch is available on some models. It is a small button or switch located above the keyboard near the hinge for the LCD. Pressing this switch when the computer is on may turn the notebook display off, or it may cause the notebook to enter a different power state. Press the switch two to three times while observing the display. If the display does not return to normal brightness when the switch is released, the switch may be sticking and need to be repaired. Contact HP service and support for further assistance. If the display turns off when the switch is pressed, the power management function may be set to hibernate or turn off when the lid is closed. Install updated BIOS and drivers To resolve certain hardware and software issues, use HP Health Check to automatically search the HP web site for an updated BIOS as well as any updated software and drivers. To launch HP Health Check, follow the steps below.
  1. Click Start , type health into the search field, and then select HP Health Check from the list. HP Health Check displays a list of available BIOS, software, and driver updates for your particular model.
  2. Click the description link for any BIOS, software, or driver updates, and then follow the on-screen instructions. You can only install one update at a time.
  3. Repeat steps 1 and 2 above for all updates that you want to install.
You have now installed the available BIOS, software, and driver updates for your particular computer model. Contact HP service and support If the display remains dim after doing the troubleshooting steps listed in this document, contact HP service and support for further assistance.
Oct 15, 2008 | Computers & Internet
LCD Display
This is a common failure on 2003 & up Accords. Honda has extended the factory warranty on this unit.
Contact your Honda dealer to see if they will cover the repair of the faulty circut board in the display.
Jul 28, 2008 | 2004 Honda Accord
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Jun 05, 2008 | HP Pavilion dv1000 Notebook
Bose Wave Radio Logo
1,363 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
