Question about Rex Sewing Machines
The thread keeps breaking on my Rex hemming machine
  • 106 Answers
SOURCE: problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Posted on Mar 29, 2008
SOURCE: HOW TO THREAD
Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful. I have the Rex518 with the original instructional manual, but the translation into English was very poor. The MSK555 is published so you can understand the manual, and figure out how to use your machine. I too am a first time user of a blind hemming machine.
Good Luck.
Posted on Jun 24, 2008
bilabon
  • 46 Answers
SOURCE: needle keeps breaking the top thread...
In general, there are three main causes for this...
wrong needles (Singer), low quality thread (dual duty or all purpose), incorrect threading. Be sure to thread the needle from front to back.
Posted on Sep 02, 2008
  • 3 Answers
SOURCE: singer 132q sewing machine
I wanted to turn my daughters old jeans into shorts since they still fit, but were too short. I was having the same problem, but I was able to make some progress. I switched the thread from a poly/cotton blend to 100% polyester and it was a big improvement. I still was unable to stitch through seams. I am going to try a more heavy duty polyester thread and an upholstery needle (18/110).
Posted on Jun 21, 2009
  • 980 Answers
SOURCE: my singer starlet 353 is giving problems. The
Remember that early Singer machines would only sew properly with number 40 or 50 mercerised thread, anything else and all sorts of things happen, top tension should be about 4 or 5
Posted on Jan 31, 2010
Rex b/s 900-pb1 wondering how heavy of a fabric will this machine stitch, particularly cordura 1000d for hiking backpack
This will depend on using the proper needle and thread on this commercial machine.
Cheers,
Embroidery Services
San Diego, CA
Jun 14, 2016 | Rex Sewing Machines
Is there a special type of monofilament thread to use?
I would suggest that you don't use this thread, it is too fine for the tension device on a domestic sewing machine, and they just don't like it. Too strong, too fine. Its best used in industrial blind hemming machines, if you look at RTW trouser hems you'll often see monofilament utilised here.
Feb 23, 2015 | Elna Quilter's Dream 6003Q
Using Juki DDL555, Thread breaks when trying to hem jeans
Sometimes using a larger needle will help. That is if it's shredding the thread when it goes through the needle which causes it to break.
Mar 25, 2013 | Juki MO-644D Mechanical Sewing Machine
Top thread keeps breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 02, 2012 | Rex RX-1804
Janome mylock 204d needle keeps breaking when sewing a rolled hem on sequined fabric
May 16, 2012 | Janome Sewing Machines
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
REX blind hem how to lock the stitch
When I purchased my blindstitch machine, I was also told to kind of snap the fabric as you pulled it our of the machine. Like you, I found that to be a little risky. Sometimes I'd just unravel what I'd sewn. I have found the most dependable thing to do is: Before removing the fabric from the machine, snip the thread between the fingers of the looper as it approaches the needle. If the loop is broken, the chain stitch will not pull out. If you cut the loop as it approaches the needle, you will get a bit longer tail so the needle doesn't come unthreaded on the next run. If you find you need a bit longer thread tail, you can pull a bit on that loop before cutting. As long as the needle has passed through the loop on the previous stitch, you'll be fine.
Dec 29, 2008 | Rex RX-518
HOW TO THREAD
Good Luck.
May 29, 2008 | Rex RX-518
Sewing Machines Logo
27 people viewed this question
Top Rex Sewing Machines Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Joseph Mueller
Joseph Mueller
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
